How do I change double spacing to single spacing?
2010-11-26T20:09:12+00:00
When typing in Microsoft Word Starter everything comes up double spaced.  How to I change to get single space lines.
Stefan Blom 352.4K Reputation points MVP Volunteer Moderator
2012-08-04T19:19:24+00:00
You need to change the document defaults so that spacing before and after are both set to zero and so that the line spacing is Single. I believe this has been discussed earlier in this (long) thread.
2010-11-26T21:30:22+00:00
And if you want it to always, from this point forward, to be the way new documents are created, after doing Doug's suggestion, click on the "Set as Default" button.
I don't have starter to check, but in full Word in the Home tab / Paragraph group an command called "Line and Paragraph Spacing" with a icon that consists of 4 horizontal lines with blue arrows pointing up and down on the left side and a downward pointing triangle on the right side.
If this proposed solution has resolved your issue(s), please mark it as  Propose as Answer  to let others know the solution that worked for you
Doug Robbins - MVP - Office Apps and Services 323.6K Reputation points MVP Volunteer Moderator
2010-11-26T21:16:23+00:00
Click on the Dialog Launcher in the Paragraph section of the Home tab of the Ribbon, or on the Line and Paragraph Spacing button immediately above the "ph" in the word "Paragraph" in that section of the Ribbon.
65 additional answers
    2016-02-15T21:46:49+00:00
    You have to search the web. There are a number of free resources online. The trick is finding them.  Here are links to some resources I've found online.  A key point to remember is that there are not any really significant changes to BASIC functionality going back as far a 2003 (and even a bit earlier).  So if you find a course or manual for an earlier version, the concepts very likely still apply. The only thing that may have changed is where the commands are hidden.  2010 and 2013 can use the MS Labs "Search" tool to find most commands, and 2016 has the built in "tell me" feature (an unfortunately dumbed down version of the search command tool).
    http://www.free-training-tutorial.com/microsoft-word-online.html - free online tutorials, looks fairly extensive
    http://www.microsofttraining.net/microsoft-training-manuals.php - download free training manuals
    https://support.office.com/en-us/article/Office-365-scenario-based-training-af07cb6b-980d-4f33-8599-322582767408?ui=en-US&rs=en-US&ad=US - Office 365/2013 Business focused tutorials
    http://www.gcflearnfree.org/office2010 - Free Office 2010 Training
    http://www.brighthub.com/computing/windows-platform/topics/microsoft-word.aspx
    https://technet.microsoft.com/en-us/library/jj871004%28v=office.16%29.aspx?f=255&MSPPError=-2147217396 - MS "quick start guides" and "What's new" - short overviews
    https://education.microsoft.com/Start/LanguageSelect?ReturnUrl=%2fgettrained%3f - MS educator site has lots of learning materials
    https://support.office.com/en-us/article/Office-Training-Center-b8f02f81-ec85-4493-a39b-4c48e6bc4bfb?ms.officeurl=training&ui=en-US&rs=en-US&ad=US - MS Training Center, basic learning tutorials
    https://www.microsoft.com/en-us/download/details.aspx?id=22781 - **MS Learning Essentials,**is old resource, but you may find some useful stuff in it.
    https://www.microsoft.com/en-us/learning/default.aspx - MS Learning site
    https://mva.microsoft.com/product-training/office-365#!index=3&lang=1033 - MS Virtual Training Center - courses for IT Pros, you may find one or two useful
    https://mva.microsoft.com/training-topics/imagine-educator-resources#!lang=1033 - MS Virtual Training Center - Educator Resources
    https://blogs.office.com/2013/03/19/free-office-webinars-every-tuesday-watch-videos-anytime/?inf\_contact\_key=afeb69c9209c5a55c4cb63625353f5b5e7620ec00602e748ad2a1750e0f637ae - 15 minute webinars on various subjects
    https://www.youtube.com/playlist?list=PLXPr7gfUMmKyE22-YpbgcDfr2SXEO7-qX - Sway tutorials (new online approximation of PPT, pretty neat)
    Also take a look at this other question, I have been posting various training links. You may find a few more useful links there
  2. Charles Kenyon 170.9K Reputation points Volunteer Moderator
    2016-02-15T21:54:52+00:00
    The manual would take up about 6 feet on a bookshelf.
    I like
    Microsoft Word 2010 Bible by Herb Tyson
