How do I change double spacing to single spacing?
2010-11-26T20:09:12+00:00
When typing in Microsoft Word Starter everything comes up double spaced.  How to I change to get single space lines.
Stefan Blom 352.4K Reputation points MVP Volunteer Moderator
2012-08-04T19:19:24+00:00
You need to change the document defaults so that spacing before and after are both set to zero and so that the line spacing is Single. I believe this has been discussed earlier in this (long) thread.
2010-11-26T21:30:22+00:00
And if you want it to always, from this point forward, to be the way new documents are created, after doing Doug's suggestion, click on the "Set as Default" button.
I don't have starter to check, but in full Word in the Home tab / Paragraph group an command called "Line and Paragraph Spacing" with a icon that consists of 4 horizontal lines with blue arrows pointing up and down on the left side and a downward pointing triangle on the right side.
If this proposed solution has resolved your issue(s), please mark it as  Propose as Answer  to let others know the solution that worked for you
Doug Robbins - MVP - Office Apps and Services 323.6K Reputation points MVP Volunteer Moderator
2010-11-26T21:16:23+00:00
Click on the Dialog Launcher in the Paragraph section of the Home tab of the Ribbon, or on the Line and Paragraph Spacing button immediately above the "ph" in the word "Paragraph" in that section of the Ribbon.
65 additional answers
    2015-09-08T16:18:44+00:00
    Thanks.  Went online and finally think found answer. At least  it worked for first try.
    Again,
    Thank you,
    Greg
    2016-02-15T20:41:40+00:00
    These were wonderful directions.  But I wish I could find a free manual for this app so I wouldn't have to continue asking questions.  Thank you for your help.
