Export Project 2010 notes data to Excel
2011-05-24T01:39:01+00:00
I am trying to export my notes field data from MS Project 2010 to Excel in order to populate other applications.
The problem I have is that the text of the notes has been pasted in from Word and contains carriage returns.
As a result when I export to Excel only the first line of the notes text - up to the first carriage return - will be exported and available in the Excel dump.
I can use a soft return (SHIFT ENTER) to replace the carriage return and can then get  all of the text but formatting is lost and it looks like a garbled mess - not withstanding the effort to manually replace all carriage returns with soft returns throughout ALL (ugh!) of the Project task notes.
Is there a solution to do this without the extreme manual effort and the substandard appearance that results?
If so, please tell, if not, then what do you recommend under the circumstances?
Many thanks in advance...
Microsoft 365 and Office | Access | For home | Windows
John Project 49,720 Reputation points Volunteer Moderator
2011-05-24T03:00:11+00:00
MickT_61,
Using an export map or simple copy and paste you will only be able to export Notes field text up to the first 255 characters or first line feed, whichever occurs first. I have a macro that will export the full notes text but unfortunately it will not preserve formatting. If you are interested, contact me at the address below. I will ask some questions.
John
jensenljatatfastmaildotdotfm
(remove obvious redundancies)
2014-02-13T19:44:12+00:00
Eddy,
This is a rather popular thread. Your e-mail address was removed, (to protect you), but you can contact me at:
(remove obvious redundancies and the 7th character is a letter
John
2013-03-08T16:54:06+00:00
Users,
NunyaBiznas contacted me separately and I provided the macro.
John
70 additional answers
    2016-09-20T20:40:37+00:00
    Hi John,
    Sorry I am brand spankin new at macros in project.  I just copied and pasted the whole thing in project per the instructions.  I also took out what looked like headers/instructions.  How do I reference excel? Can you guide the non technical?  :)
    Patti
    2016-09-20T20:50:25+00:00
    I am trying to send you the screen shot but it won't work.  Can you send an email to ******@hotmail.com and I can send to you.
    Patti
