Office 2010: printing does not respect properties of printer
2010-07-01T07:32:35+00:00
I am using O2010 Professional Plus UK. It seems that O2010 ignores all setting of the Properties of the printer and only applies the settings you see on the print page of Office itself. That means that all other options of the printer are out of reach: O2010 just ignores them.
This issue is only with O2010 and not with any other software so it clearly must be an O2010 problem.
I am using a Vista 32bit UK OS.
Any help in solving this is more than welcome!
Michael
2010-07-16T22:01:37+00:00
It suggests an incompatible printer driver or the driver is damaged. Download the latest version of the driver, then delete and reinstall the printer. If it persists, take it up with the printer manufacturers support site to see if they have a solution.
-- Terry Farrell - MSWord MVP
2012-07-30T05:43:33+00:00
Problem:  Microsoft Word 2010 ignores printer settings when in Compatability Mode.  When in Word 2010 mode it prints fine.  For example: try printing 2 copies, or a page range, current page or anything else in any compatability mode document created in any verson of Word and it does not work.  It will print a full copy of the document.  But it ignores everything else.
Temp fix:  I have people convert the document to Word 2010 format to do any kind of special printing.  If they want the page range or 2 copies or anything else it has to be done from Word 2010 format.
Keep in mind that Word 2007 DocX format is Different than Word 2010 DocX and so 2007 docs come up as compatability mode as well and have the same issues as any other .doc docs.
MS should fix this.  I know office 2012 is about to release, but this is a really bad bug.  I have this issue on brand new images running Windows 7 Pro (updated), Drivers for all the printers updated, and the issue is happening on all the many types of printers we have.   Not a driver issue.  Word issue.
By the way, the version of Word 2010 is the corporate version with sp1 built in.  Not sure if that makes any difference.  I don't have 2010 without sp1.  Maybe that has less issues.  Curious if the guys not experiencing this are running a previous version of 2010.
Chris
61 additional answers
    2010-10-19T19:15:21+00:00
    Terry Farrell - you are an MSWord MVP?  And you really think that just because you don't have the problem its not a problem with word?
    I'm thinking the other guys are right here.  I have several customers with the same issue.  The issue only came up since installation of Office 2010.  They can print a PDF, from the internet, or any other program.  But when it comes to Office 2010 - it seems to ignore the settings for the printer.  Unless you change the default settings in windows for the printer the settings are not applied.  This is not acceptable.  End users need to be able to have access to these settings.
    Instead of just insisting it is not an Office 2010 problem, do you or anyone else have some actual valuable information that could help resolve this issue?
    David
    2010-11-17T11:04:32+00:00
    Has anyone got anywhere with this? We're seeing similar issues at the start of an Office 2010 rollout, this time with secure printing. If you select output type in the printer properties as "secure print" then launch Word & print it's fine, but when you then relaunch Word it prints unsecure. Going back to the printer properties shows that "secure print" has been deselected. The print queues are config'd to print secure as default so it seems as if Word 2010 is actually overwriting the printer properties rather than just ignoring them.
    And yes, latest print drivers installed, read all the Microsoft stuff already, all non-Office software prints fine.
    2010-11-29T18:41:43+00:00
    It is definately Office 2010 that is the problem as mine worked perfectly fine before I upgraded to Office 2010 and still works fine with older versions of Office. Is there a fix for it yet? It is really starting to bug me!
