Office 2010: printing does not respect properties of printer
2010-07-01T07:32:35+00:00
I am using O2010 Professional Plus UK. It seems that O2010 ignores all setting of the Properties of the printer and only applies the settings you see on the print page of Office itself. That means that all other options of the printer are out of reach: O2010 just ignores them.
This issue is only with O2010 and not with any other software so it clearly must be an O2010 problem.
I am using a Vista 32bit UK OS.
Any help in solving this is more than welcome!
Michael
2010-07-16T22:01:37+00:00
It suggests an incompatible printer driver or the driver is damaged. Download the latest version of the driver, then delete and reinstall the printer. If it persists, take it up with the printer manufacturers support site to see if they have a solution.
-- Terry Farrell - MSWord MVP
2012-07-30T05:43:33+00:00
Problem:  Microsoft Word 2010 ignores printer settings when in Compatability Mode.  When in Word 2010 mode it prints fine.  For example: try printing 2 copies, or a page range, current page or anything else in any compatability mode document created in any verson of Word and it does not work.  It will print a full copy of the document.  But it ignores everything else.
Temp fix:  I have people convert the document to Word 2010 format to do any kind of special printing.  If they want the page range or 2 copies or anything else it has to be done from Word 2010 format.
Keep in mind that Word 2007 DocX format is Different than Word 2010 DocX and so 2007 docs come up as compatability mode as well and have the same issues as any other .doc docs.
MS should fix this.  I know office 2012 is about to release, but this is a really bad bug.  I have this issue on brand new images running Windows 7 Pro (updated), Drivers for all the printers updated, and the issue is happening on all the many types of printers we have.   Not a driver issue.  Word issue.
By the way, the version of Word 2010 is the corporate version with sp1 built in.  Not sure if that makes any difference.  I don't have 2010 without sp1.  Maybe that has less issues.  Curious if the guys not experiencing this are running a previous version of 2010.
Chris
61 additional answers
    2010-07-30T17:45:00+00:00
    "Jeff.D." wrote in message news:Email removed for privacy...
    I'm experiencing this as well.  As a workaround I am able to change the properties of the printer from windows before opening word then the settings carry on to word.  Not sure why it's happening and nobody seems to have a fix for it.
    Terry Farrell
    Anyone find an answer to this?  It isn't a driver issue since it's happening on several different models all with the latest drivers from their manufacturer.  Also printing in any other program, such as IE8 etc works great.  The problem is only in the office applications.
    2010-08-02T18:34:00+00:00
    Ok, I'm wondering how many people will have to post with the issue before you will stop pointing the finger at the printer manufacturer.  LET us recap....Multiple printer models, ALL with current drivers, ALL work fine in every other concievable program EXCEPT Office 2010.  Hmmm, doesn't take much of a genius to figure this one out.  Do you think there might be an issue in OFFICE 2010?  Do you really think we would waste our time scouring the internet for a solution when we hadn't already tried the most basic solution of installing the latesest driver?  I know, I'm being a little sarcastic but I get really tired of seeing the same typical junk responses to people concerns.  How about trying to give it a little more thought and maybe give people the benefit of the doubt that there really is something wrong.
    2010-08-02T19:10:19+00:00
    Works OK with the 2 printers I have access to, so I don’t see it as a Word problem.
    What happens if you start Word in Safe Mode? Will it pick up the settings when you print in Safe Mode?
