Office 2010: printing does not respect properties of printer
2010-07-01T07:32:35+00:00
I am using O2010 Professional Plus UK. It seems that O2010 ignores all setting of the Properties of the printer and only applies the settings you see on the print page of Office itself. That means that all other options of the printer are out of reach: O2010 just ignores them.
This issue is only with O2010 and not with any other software so it clearly must be an O2010 problem.
I am using a Vista 32bit UK OS.
Any help in solving this is more than welcome!
Michael
2010-07-16T22:01:37+00:00
It suggests an incompatible printer driver or the driver is damaged. Download the latest version of the driver, then delete and reinstall the printer. If it persists, take it up with the printer manufacturers support site to see if they have a solution.
-- Terry Farrell - MSWord MVP
2012-07-30T05:43:33+00:00
Problem:  Microsoft Word 2010 ignores printer settings when in Compatability Mode.  When in Word 2010 mode it prints fine.  For example: try printing 2 copies, or a page range, current page or anything else in any compatability mode document created in any verson of Word and it does not work.  It will print a full copy of the document.  But it ignores everything else.
Temp fix:  I have people convert the document to Word 2010 format to do any kind of special printing.  If they want the page range or 2 copies or anything else it has to be done from Word 2010 format.
Keep in mind that Word 2007 DocX format is Different than Word 2010 DocX and so 2007 docs come up as compatability mode as well and have the same issues as any other .doc docs.
MS should fix this.  I know office 2012 is about to release, but this is a really bad bug.  I have this issue on brand new images running Windows 7 Pro (updated), Drivers for all the printers updated, and the issue is happening on all the many types of printers we have.   Not a driver issue.  Word issue.
By the way, the version of Word 2010 is the corporate version with sp1 built in.  Not sure if that makes any difference.  I don't have 2010 without sp1.  Maybe that has less issues.  Curious if the guys not experiencing this are running a previous version of 2010.
Chris
61 additional answers
  1. Doug Robbins - MVP - Office Apps and Services 323.6K Reputation points MVP Volunteer Moderator
    2013-02-18T21:41:30+00:00
    See my response to Dale.  While I do not work for a Printer Manufacturer, I have been using Word extensively mostly with high end printers and I have never come across the problem.  It is also possible that Group Policy Settings are coming into play.
    2013-04-25T09:17:09+00:00
    The problem is that the Office print options override the default printer settings.
    I have a workaround for Outlook:
    In the print menu, choose Define Styles
    Create a copy of the style you use most (e.g. Memo Style)
    Label the copy appropriately (e.g. tray 2) and set the paper source as appropriate (tray 2) on the Paper tab.
    Ensure the original Style setting uses another tray (e.g. tray 1).
    Then when printing, choose the appropriate style for the required tray.
    Microsoft, please fix this in SP2!
    2013-09-25T16:21:13+00:00
    Make sure your printer driver is up to date, either directly from the printer manufacturer or via windows update.
    Also, the has been a recent service-pack released for Microsoft office 2010 i believe it is SP2, ensure that your office is updated with this and it should resolve the issue.
