click-2-run configuration failure
2010-02-22T09:47:55+00:00
I installed word 2010 beta, and I cant open it.
I just get the above message
2011-10-19T22:55:06+00:00
I had all of the same problems listed above, with no luck. I tried uninstalling, or repairing and no luck. I am using Windows 7, and using the Microsoft Office Starter that came pre-packaged with a new laptop. This laptop is less than 2 weeks old and Office started acting up a couple days after we got it. I have gone over and over the forums and tech supports with no luck.
I took an alternate approach to repairing the "Click-2-Run Configuration Failure" that WORKED (For me). I hope this helps others, the approach is very simple that anyone with ADMIN rights should be able to do this.
Solution that worked for me...
1.) Create an alternate User Account on the computer.
2.) Restart the computer and Login to the new user account.
3.) Open the Microsoft Office Starter from "All Programs"
4.) Click on Word or Excel
5.) The program should start loading all files needed from the Microsoft server.
6.) Once all files are loaded, you should be able to access your Microsoft Office Starter Programs. (Open and confirm.)
7.) "Switch User" to your ORIGINAL ACCOUNT
8.) Click one of the Microsoft Office Starter programs and hopefully it will start working.
9.) NOTE: I have not yet deleted the new user account, so results may vary.
Good luck,
46 additional answers
    2011-12-15T19:21:58+00:00
    Ive got 3 letters for you M-A-C :) NEVER DEAL WITH WINDOW BULLSHIT EVER AGAIN
    2012-03-06T15:56:52+00:00
    Like others, can't remove (or delete) the temp drive, so it's a non-starter
    2012-03-09T14:48:54+00:00
    This is ridiculous. I am a student and I need to use this to do the majority of my written work.
    It has not been possible to use it because of this click-2-run error constantly attacking me.
  4. Doug Robbins - MVP - Office Apps and Services 323.6K Reputation points MVP Volunteer Moderator
    2012-03-10T00:43:04+00:00
    See http://office.microsoft.com/en-us/word-help/click-to-run-switch-to-using-an-msi-based-office-edition-HA101850538.aspx
    Hope this helps.
    Doug Robbins - Word MVP,
    Email: dkr[atsymbol]mvps[dot]org
    Posted via the Community Bridge
    "LiamSimmons" wrote in message news:******@communitybridge.codeplex.com.word...
    http://answers.microsoft.com/message/252d8741-a7dc-4ade-ba1e-8b2699ef1e59?threadId=2ce975a9-90e9-4919-89d2-da64440e1423
    Meta tags: windows_xp; word; office_2010
    Fri, 9 Mar 2012 14:48:54  +0000: CreateMessage  LiamSimmons
