click-2-run configuration failure
2010-02-22T09:47:55+00:00
I installed word 2010 beta, and I cant open it.
I just get the above message
2011-10-19T22:55:06+00:00
I had all of the same problems listed above, with no luck. I tried uninstalling, or repairing and no luck. I am using Windows 7, and using the Microsoft Office Starter that came pre-packaged with a new laptop. This laptop is less than 2 weeks old and Office started acting up a couple days after we got it. I have gone over and over the forums and tech supports with no luck.
I took an alternate approach to repairing the "Click-2-Run Configuration Failure" that WORKED (For me). I hope this helps others, the approach is very simple that anyone with ADMIN rights should be able to do this.
Solution that worked for me...
1.) Create an alternate User Account on the computer.
2.) Restart the computer and Login to the new user account.
3.) Open the Microsoft Office Starter from "All Programs"
4.) Click on Word or Excel
5.) The program should start loading all files needed from the Microsoft server.
6.) Once all files are loaded, you should be able to access your Microsoft Office Starter Programs. (Open and confirm.)
7.) "Switch User" to your ORIGINAL ACCOUNT
8.) Click one of the Microsoft Office Starter programs and hopefully it will start working.
9.) NOTE: I have not yet deleted the new user account, so results may vary.
Good luck,
46 additional answers
    2011-06-12T21:41:55+00:00
    why did microsoft created this monster that gave so much misery to their clients?!? i just can't understand! don't they want to give better products to the public!?
  2. Stefan Blom 353.5K Reputation points MVP Volunteer Moderator
    2011-06-15T08:36:45+00:00
    Note that beta products are used at your own risk.
  3. Stefan Blom 353.5K Reputation points MVP Volunteer Moderator
    2011-06-15T09:35:11+00:00
    This solution and links did not work for me.  Is there a removal tool from Microsoft?
    The only "removal tool" that I know of is the following:
    How do I uninstall Office 2003, Office 2007 or Office 2010 suites if I cannot uninstall it from Control Panel?
    http://support.microsoft.com/kb/290301/en-us
  4. Stefan Blom 353.5K Reputation points MVP Volunteer Moderator
    2011-06-15T09:37:58+00:00
    > Please stop posting this silly link. The instructions to Uninstall
    > are to use the Add/Remove Programs utility. Don't you think
    > we've already tried that? Obviously that isn't working.
    You realize of course that if you don't explain what you have tried, then it's difficult for other people to know.
