click-2-run configuration failure
2010-02-22T09:47:55+00:00
I installed word 2010 beta, and I cant open it.
I just get the above message
2011-10-19T22:55:06+00:00
I had all of the same problems listed above, with no luck. I tried uninstalling, or repairing and no luck. I am using Windows 7, and using the Microsoft Office Starter that came pre-packaged with a new laptop. This laptop is less than 2 weeks old and Office started acting up a couple days after we got it. I have gone over and over the forums and tech supports with no luck.
I took an alternate approach to repairing the "Click-2-Run Configuration Failure" that WORKED (For me). I hope this helps others, the approach is very simple that anyone with ADMIN rights should be able to do this.
Solution that worked for me...
1.) Create an alternate User Account on the computer.
2.) Restart the computer and Login to the new user account.
3.) Open the Microsoft Office Starter from "All Programs"
4.) Click on Word or Excel
5.) The program should start loading all files needed from the Microsoft server.
6.) Once all files are loaded, you should be able to access your Microsoft Office Starter Programs. (Open and confirm.)
7.) "Switch User" to your ORIGINAL ACCOUNT
8.) Click one of the Microsoft Office Starter programs and hopefully it will start working.
9.) NOTE: I have not yet deleted the new user account, so results may vary.
Good luck,
46 additional answers
    2010-04-13T21:05:37+00:00
    Cannot remove the temporary drive, cannot uninstall Click-2-Run
    Any other bright ideas?
    2010-02-23T00:51:20+00:00
    Click-2-Run is the Application Virtualization (App-V) streaming version of Office 2010. It was put out there so people could install it side by side with Office 2007 without affecting their computer. Downloading a program using Click2Run creates a temp drive.
    Remove the drive (which can be with any name other then the one you use by default). Check any drive that got created (drive which you normally don’t find in your system). Remove the drive.
    Open the temp folder and delete all the files in the temp folder.
    Try to uninstall Click-2-Run from Windows installed application under Control Panel--> Programs and Features.
    Restart the computer and click on the link below:-
    http://us20.office2010beta.microsoft.com/product.aspx?sku=10199928&culture=en-US to get the Click-2-Run version or
    http://us20.office2010beta.microsoft.com/product.aspx?sku=10199914&culture=en-US for the traditional install.
    Vinay G, Microsoft Answers Support Engineer.
    • We appreciate your participation in MS Forums, Help us understand your needs better. To share your valuable Feedback please Click here.
