how to uninstall OneNote
2010-07-13T02:52:38+00:00
hello,
i have a sony vaio with windows vista, would like to know how to uninstall OneNote 2007. i accently clicked on the ballon on the bottom of my screen and it installed and i really dislike this program. ive tried looking for an uninstall icon in the program files from hard drive, but there was none.
any help would be appreciated,
Leonard
Microsoft 365 and Office
A comprehensive suite of productivity tools and cloud services that enhance collaboration, communication, and efficiency. Combining classic Office apps with advanced Microsoft 365 features, it supports both personal and business needs
2011-10-16T19:19:52+00:00
I am not sure why this has become such a hot button issue. I am sorry that my comments have made it worse.
I added the remove instructions at the top f the thread because I thought it would help people. It was done directly from my uninstalling it for a test. Let me repeat the basics of that instruction, since a piece of it seems to have gotten lost:
From Start --> Control Panel --> Programs and Features, find your version of Office in the list of programs. Click the "Change" link at the top of the list. Wait for Office to do the set up. On the list of options, select "Add or Remove Features". Click Continue. Select OneNote from the list. RIght click it and select "Not Availalbe", then click continue again. Your computer will buzz for a while.... When done, OneNote should be removed from your computer.
Please be sure that you have another printer available to that machine so that you get a new default printer once Send to OneNote is gone.
As for the other question: No - OneNote doesn't slow down my machine. I usually have at least one instance of it up and I don't see any slow down at all. In fact, installing it and getting it set up only takes a minute or two on my machines. I would love to know more about what is on your machines that is causing the slow down.
Some of us do care about OneNote problems. Just because I can't live without it doesn't mean you should use it. I am sorry for the problems this thread has caused.
92 additional answers
    2016-07-21T02:30:41+00:00
    I am trying to uninstall One Note from my new laptop which is running Windows 10, it is irritating as it keeps appearing in my task bar for no reason. I never use it.
    I took care of OneNote on my machine. I am running Windows 10 PRO.
    First, OneNote cannot be uninstalled! It can be put out of service. You have to have the PRO version of software to stop it from working. If you or others have the PRO version I will post the directions to disable OneNote. I have it as a step by step method. It has to be followed exactly with each step. If anyone wants the directions I will post them.
    Remember that it only works in the PRO version. OneNote cannot be uninstalled, only disabled.
    2016-09-29T08:39:51+00:00
    This didn't work for me. The only options in the change box were quick repair or online repair. Looks like MS would rather me dump Windows and change to Linux or Mac than let me be free of this OneNote virus that keeps taking over print and other things that I use regularly.
    2016-12-10T17:07:55+00:00
    Regarding your commenting about disliking One Note. I can assure you that anyone who has had to support users who sends stuff to the One Note "printer" and wants me to fix their printer that I despise a company that installs software on computers without the users knowledge or acceptance. Perhaps you could explain why Microsoft reinstalls One Note with various updates?
    2017-07-18T21:59:49+00:00
    hello,
    Leonard
