Word crashes when I perform a simple copy and paste or select and drag?
2011-07-13T08:59:16+00:00
Why does Word crash when I perform a simple copy and paste or select and drag?
2011-10-26T11:39:34+00:00
Here is the solution to your Copy - Paste nightmares.... The word software needs to be reset.  Don't panic you won't lose your documents.
Step (1) Close all your open programs
Step (2) Open Finder
Step (3) Press and Hold Option button, then click GO on the top tool bar. Keep holding the Option button down and click on Library
Step (4) In the Library, click on Preferences
Step (5) Look for the file com.microsoft.word.plist
Step (6) Move the file to your desktop
Step (7) Close the Library file
Step (8) Open Word again, this will take you through a Welcome screen. Which means your word software is reset.
This fix has worked for me for over a week now and the Save button is thanking me!  Keep the .plist file on your desktop, if something hits the fan you can always reset your settings.
Good luck fellow pasters!
2015-02-10T23:59:21+00:00
I just found this on the net & it works for me on text pasted from a web page. In word use edit, paste special and select unformatted
good luck!
Try Paste Special.
  1. Press ALT/CTRL/V.
  2. Select Unformatted Text in the As list box.
  3. Click OK.
Jim G 134K Reputation points MVP
2012-07-01T23:02:45+00:00
It turns out the Java malware problem was widespread. As you can see from the thread there are several possible causes of the problem. If you want assistance solving your particular problem, post a new question with as much detail as you can supply about your system, update level of Word and Mac OS X, what sort of thing you're trying to copy that causes the crash, a bit of the crash log, etc.
74 additional answers
    2011-12-11T08:47:44+00:00
    Another one to add to the list same problem. Done the Maggie and the plist removal and just when I thought it was fixed, the problem comes back - invariably after lulling me into a false sense of security when I'm not hitting the save button so often! I keep sending in the crash reports thinking that something might be done. Does anyone from the Word for Mac development team see any of these forums?
    2011-12-11T09:46:14+00:00
    It is really vexing. I am a die hard Mac person and rather down on Microsoft. But I must say I feel the whole Lion transition has been difficult. I guess it is a matter of the developers catching up to the new platform whose benefits seem a bit less than worth it at the moment. But in defense of microsoft, there are other programs that either seem so to struggle with Lion or that simply do not work. That said, Microsoft, come on!
