Word crashes when I perform a simple copy and paste or select and drag?
2011-07-13T08:59:16+00:00
Why does Word crash when I perform a simple copy and paste or select and drag?
2011-10-26T11:39:34+00:00
Here is the solution to your Copy - Paste nightmares.... The word software needs to be reset.  Don't panic you won't lose your documents.
Step (1) Close all your open programs
Step (2) Open Finder
Step (3) Press and Hold Option button, then click GO on the top tool bar. Keep holding the Option button down and click on Library
Step (4) In the Library, click on Preferences
Step (5) Look for the file com.microsoft.word.plist
Step (6) Move the file to your desktop
Step (7) Close the Library file
Step (8) Open Word again, this will take you through a Welcome screen. Which means your word software is reset.
This fix has worked for me for over a week now and the Save button is thanking me!  Keep the .plist file on your desktop, if something hits the fan you can always reset your settings.
Good luck fellow pasters!
2015-02-10T23:59:21+00:00
I just found this on the net & it works for me on text pasted from a web page. In word use edit, paste special and select unformatted
good luck!
Try Paste Special.
  1. Press ALT/CTRL/V.
  2. Select Unformatted Text in the As list box.
  3. Click OK.
Jim G 134K Reputation points MVP
2012-07-01T23:02:45+00:00
It turns out the Java malware problem was widespread. As you can see from the thread there are several possible causes of the problem. If you want assistance solving your particular problem, post a new question with as much detail as you can supply about your system, update level of Word and Mac OS X, what sort of thing you're trying to copy that causes the crash, a bit of the crash log, etc.
74 additional answers
    2011-10-19T16:51:05+00:00
    Well, I'm having the same problem. I was editing a very large file (.doc) in Word 2011 for the Mac on my recently bought iMac (Mac OS X 10.6.8) and it crashes all the time I'm correcting with the function for that. It can't handle such large files. I've heard the same problem from someone using Office 2007 on a pc, by the way. So it's a known problem.
    I think the problem lies in the clipboard-function. Apparently it remembers every single action I've taken, no matter how great or small, and it won't empty. Only after a system crash I received an error message asking if I wanted to keep all content on the clipboard.
    On a pc you can manually empty the clipboard of Word. But how can you do that on a Mac?!
    2011-10-19T17:54:29+00:00
    I am not sure if it is really the size because I have managed to open very large files >1k pages without a problem. Recently I realized that the program is crashing also after a certain period of time, so maybe it is not related only to the copy-pasting.
    I must admit that this investment was a disaster; I have no option other than keep working with a program that is crashing continuously during a working day - and have become obsessed with the save button. Alternatively I could maintain two laptops or start using MS Office in Windows emulation mode. All are terrible options!
    It is still a mystery to me why Microsoft is not fixing this bug. I believe that most Mac users will never make a transition back to Windows and sooner or later someone will find an alternative. So even as a strategy it doesn't make sense.
