Word crashes when I perform a simple copy and paste or select and drag?
2011-07-13T08:59:16+00:00
Why does Word crash when I perform a simple copy and paste or select and drag?
2011-10-26T11:39:34+00:00
Here is the solution to your Copy - Paste nightmares.... The word software needs to be reset.  Don't panic you won't lose your documents.
Step (1) Close all your open programs
Step (2) Open Finder
Step (3) Press and Hold Option button, then click GO on the top tool bar. Keep holding the Option button down and click on Library
Step (4) In the Library, click on Preferences
Step (5) Look for the file com.microsoft.word.plist
Step (6) Move the file to your desktop
Step (7) Close the Library file
Step (8) Open Word again, this will take you through a Welcome screen. Which means your word software is reset.
This fix has worked for me for over a week now and the Save button is thanking me!  Keep the .plist file on your desktop, if something hits the fan you can always reset your settings.
Good luck fellow pasters!
2015-02-10T23:59:21+00:00
I just found this on the net & it works for me on text pasted from a web page. In word use edit, paste special and select unformatted
good luck!
Try Paste Special.
  1. Press ALT/CTRL/V.
  2. Select Unformatted Text in the As list box.
  3. Click OK.
Jim G 134K Reputation points MVP
2012-07-01T23:02:45+00:00
It turns out the Java malware problem was widespread. As you can see from the thread there are several possible causes of the problem. If you want assistance solving your particular problem, post a new question with as much detail as you can supply about your system, update level of Word and Mac OS X, what sort of thing you're trying to copy that causes the crash, a bit of the crash log, etc.
74 additional answers
    2011-09-15T20:26:41+00:00
    But what if you're working with users who are still on older versions of Word? Won't saving as .docx cause problems for those users or will the issue come back when they save changes and it goes back to .doc? This has been a major issue for all of our users who have moved to 2011 so far.
    2011-10-18T17:10:28+00:00
    I'm seeing the same problem as others - copy and paste or select and drag are producing freezes, whether they are in a document or coming from other applications. It's unpredictable; sometimes it works, other times it doesn't. No other signs of corruption in the .doc file affected, but it's bad enough to make Word 2011 unusable.
    This is a Word problem that causes lost work, guys, and with Nisus Writer and Pages on my Mac, Word is going on the shelf unless MS fixes it.
