Word crashes when I perform a simple copy and paste or select and drag?
2011-07-13T08:59:16+00:00
Why does Word crash when I perform a simple copy and paste or select and drag?
2011-10-26T11:39:34+00:00
Here is the solution to your Copy - Paste nightmares.... The word software needs to be reset.  Don't panic you won't lose your documents.
Step (1) Close all your open programs
Step (2) Open Finder
Step (3) Press and Hold Option button, then click GO on the top tool bar. Keep holding the Option button down and click on Library
Step (4) In the Library, click on Preferences
Step (5) Look for the file com.microsoft.word.plist
Step (6) Move the file to your desktop
Step (7) Close the Library file
Step (8) Open Word again, this will take you through a Welcome screen. Which means your word software is reset.
This fix has worked for me for over a week now and the Save button is thanking me!  Keep the .plist file on your desktop, if something hits the fan you can always reset your settings.
Good luck fellow pasters!
2015-02-10T23:59:21+00:00
I just found this on the net & it works for me on text pasted from a web page. In word use edit, paste special and select unformatted
good luck!
Try Paste Special.
  1. Press ALT/CTRL/V.
  2. Select Unformatted Text in the As list box.
  3. Click OK.
Jim G 134.1K Reputation points MVP
2012-07-01T23:02:45+00:00
It turns out the Java malware problem was widespread. As you can see from the thread there are several possible causes of the problem. If you want assistance solving your particular problem, post a new question with as much detail as you can supply about your system, update level of Word and Mac OS X, what sort of thing you're trying to copy that causes the crash, a bit of the crash log, etc.
74 additional answers
    2013-05-21T07:39:44+00:00
    This is a NIGHTMARE. Happens over and over, can't use the program at all. Can't believe I wasted good money "upgrading" to what, for me, is now a useless waste of space.
    Please tell me there is a fix, and that Microsoft isn't really this incompetent.
    In the Name of Allah.
    Salam.
    Dear friend,
    I found the solution after several days of being perplexed and frustrated, I finally found the solution, by Allah's help:
    Open and save the document in the compatibility mode: word 97-2003.
    The issue was resolved for me.
    Hope it will solve it for u, too!
    Best.
  2. Jim G 134.1K Reputation points MVP
    2013-05-21T15:16:46+00:00
    Salam.
    Dear friend,
    Best.
    The Save As option you mentioned appears only in Word for Windows, not Word for Mac. The question you responded to is about Microsoft Word 2011 for Mac, not the PC version of Word.
