Word crashes when I perform a simple copy and paste or select and drag?
2011-07-13T08:59:16+00:00
Why does Word crash when I perform a simple copy and paste or select and drag?
2011-10-26T11:39:34+00:00
Here is the solution to your Copy - Paste nightmares.... The word software needs to be reset.  Don't panic you won't lose your documents.
Step (1) Close all your open programs
Step (2) Open Finder
Step (3) Press and Hold Option button, then click GO on the top tool bar. Keep holding the Option button down and click on Library
Step (4) In the Library, click on Preferences
Step (5) Look for the file com.microsoft.word.plist
Step (6) Move the file to your desktop
Step (7) Close the Library file
Step (8) Open Word again, this will take you through a Welcome screen. Which means your word software is reset.
This fix has worked for me for over a week now and the Save button is thanking me!  Keep the .plist file on your desktop, if something hits the fan you can always reset your settings.
Good luck fellow pasters!
2015-02-10T23:59:21+00:00
I just found this on the net & it works for me on text pasted from a web page. In word use edit, paste special and select unformatted
good luck!
Try Paste Special.
  1. Press ALT/CTRL/V.
  2. Select Unformatted Text in the As list box.
  3. Click OK.
Jim G 134K Reputation points MVP
2012-07-01T23:02:45+00:00
It turns out the Java malware problem was widespread. As you can see from the thread there are several possible causes of the problem. If you want assistance solving your particular problem, post a new question with as much detail as you can supply about your system, update level of Word and Mac OS X, what sort of thing you're trying to copy that causes the crash, a bit of the crash log, etc.
74 additional answers
    2011-09-08T06:37:30+00:00
    Yes, I agree. We need more than a 'Maggie'. It must be a bug that has to be fixed by Microsoft...
    2011-09-08T09:33:01+00:00
    I have very serious problems with Microsoft Word 2011. The program is crashing all the time when working with it, having serious impact on the quality and speed of my work. I have try to locate the problem and I have noticed that the crashes happens when copying and pasting text/figures, however I can't say that these are the only reasons because the crashes happen also randomly. With every crash my computer sends an automated report to Microsoft, but these reports have been send to MS since April 2011 and so far no update has resolved the problem. I think it is completely irresponsible from Microsoft to not be able to provide a fix for this problem although these bugs are out for at least half a year. Also I find irresponsible that for example applications like Visio and Project are not supported in MAC.
    I must also admit that from all applications in my MAC the only problematic are the ones from Microsoft - this is an absolutely sincere opinion and not a Mac user biased one.
