Word crashes when I perform a simple copy and paste or select and drag?
2011-07-13T08:59:16+00:00
Why does Word crash when I perform a simple copy and paste or select and drag?
2011-10-26T11:39:34+00:00
Here is the solution to your Copy - Paste nightmares.... The word software needs to be reset.  Don't panic you won't lose your documents.
Step (1) Close all your open programs
Step (2) Open Finder
Step (3) Press and Hold Option button, then click GO on the top tool bar. Keep holding the Option button down and click on Library
Step (4) In the Library, click on Preferences
Step (5) Look for the file com.microsoft.word.plist
Step (6) Move the file to your desktop
Step (7) Close the Library file
Step (8) Open Word again, this will take you through a Welcome screen. Which means your word software is reset.
This fix has worked for me for over a week now and the Save button is thanking me!  Keep the .plist file on your desktop, if something hits the fan you can always reset your settings.
Good luck fellow pasters!
2015-02-10T23:59:21+00:00
I just found this on the net & it works for me on text pasted from a web page. In word use edit, paste special and select unformatted
good luck!
Try Paste Special.
  1. Press ALT/CTRL/V.
  2. Select Unformatted Text in the As list box.
  3. Click OK.
Jim G 134K Reputation points MVP
2012-07-01T23:02:45+00:00
It turns out the Java malware problem was widespread. As you can see from the thread there are several possible causes of the problem. If you want assistance solving your particular problem, post a new question with as much detail as you can supply about your system, update level of Word and Mac OS X, what sort of thing you're trying to copy that causes the crash, a bit of the crash log, etc.
74 additional answers
    2011-07-13T09:09:29+00:00
    Because the document's internal code is corrupted.  It's usually a problem with numbering or tables.
    Try a Maggie:
    The Maggie:
    1. Create a new blank document in .docx format
    2. Carefully select all of the text in the bad document EXCEPT the last
    paragraph mark
    1. Copy it.
    2. Paste in the new document.
    3. Save under a new file name and close all, then re-open.
    This technique for de-corrupting is known as "Doing a 'Maggie'", after
    Margaret Secara from the TECHWR-L mailing list, who first publicised the
    technique.
    Cheers
    2011-09-07T17:39:44+00:00
    I don't know about anyone else - but this doesn't help.
    I find that when I am heavily working word crashes because of pasting at least 20 times a day.  In brand new documents, documents I have created, or documents that someone else has sent to me for working.
    I reckon I waste an 1and 1/2 on this a day.
    Looking at a range of forums this is clearly an issue that others face and it would be really good if it was addressed (and yes my office is up-to-date).
    Now it may be that the document's internal code is continuously being corrupted - but that sounds like a bug in word that needs fixing.
