Word crashes when I perform a simple copy and paste or select and drag?
2011-07-13T08:59:16+00:00
Why does Word crash when I perform a simple copy and paste or select and drag?
2011-10-26T11:39:34+00:00
Here is the solution to your Copy - Paste nightmares.... The word software needs to be reset.  Don't panic you won't lose your documents.
Step (1) Close all your open programs
Step (2) Open Finder
Step (3) Press and Hold Option button, then click GO on the top tool bar. Keep holding the Option button down and click on Library
Step (4) In the Library, click on Preferences
Step (5) Look for the file com.microsoft.word.plist
Step (6) Move the file to your desktop
Step (7) Close the Library file
Step (8) Open Word again, this will take you through a Welcome screen. Which means your word software is reset.
This fix has worked for me for over a week now and the Save button is thanking me!  Keep the .plist file on your desktop, if something hits the fan you can always reset your settings.
Good luck fellow pasters!
2015-02-10T23:59:21+00:00
I just found this on the net & it works for me on text pasted from a web page. In word use edit, paste special and select unformatted
good luck!
Try Paste Special.
  1. Press ALT/CTRL/V.
  2. Select Unformatted Text in the As list box.
  3. Click OK.
Jim G 134.1K Reputation points MVP
2012-07-01T23:02:45+00:00
It turns out the Java malware problem was widespread. As you can see from the thread there are several possible causes of the problem. If you want assistance solving your particular problem, post a new question with as much detail as you can supply about your system, update level of Word and Mac OS X, what sort of thing you're trying to copy that causes the crash, a bit of the crash log, etc.
74 additional answers
    2013-02-26T23:10:31+00:00
    Wow! I have no idea why this works but so far so good. I was getting crashes every hour. I am knocking on wood while I speak. I am certainly willing to reformat non-text if I must in order to stop the crashes.
    I just copied and pasted something over and over--no crashes.
    Bless you!!
    2013-02-26T16:15:13+00:00
    The same thing was happening with me so what I did was I went into Word Options by clicking the office button on the top left hand corner in your word document.  Click on work options at the bottom right hand corner of the list.  Click on the advanced tab on the left hand side and under the copy, cut and paste section change the drop down menu to Keep Text Only.  There is about four of them to change.  After doing this and then cutting, copying and pasting, I had no more troubles.
    I don't know why it happens but my husband and I figured out this solution and it seems to have worked.  I can still perform the options without the formatting from the document to which I am taking the information from.
    I hope this helps!
