How do you stop words from being split across two lines in Word 2010?
2010-08-10T23:06:00+00:00
Help please, have installed Word 2010 and cannot work out why the words get split at the end of a line, leaving half the word on one line and the other half getting pushed onto the next.  Any ideas much appreciated!
2014-11-26T10:34:35+00:00
The same problem with Microsoft Word can be solved by the following steps:
1- Close Word
2- Navigate to Start->Programs->Microsoft Office->Microsoft Office Tools->Microsoft Office Language Preference
3- Add Japanese
4- Open Word
5- In right Click menu: Select Paragraph...
6- Go to the "Asian Typography" Tab.
7- Deselect: "Allow Latin text to wrap in the middle of a word"
8- Click OK
The problem will be solved. Now if you don't want to have Japanese you can remove it from:
Good Luck!
2013-03-26T01:12:39+00:00
I have found the solution (a little late, yes, but useful nowadays since no one was able to figure it out). It has to do with the Japanese language support (I don't know why, but it is like that). I found the solution here: http://www.mraggarwal.com/2007/05/11/powerpoint-word-wrap-splitting-words-down-the-middle/ I hope it helps to the people having this issue and I also hope that Microsoft takes a look at this weird issue.
2010-08-11T08:23:35+00:00
Word should not split words like that. It suggests a serious bug with the printer driver. Try switching printers or updating your existing printer driver.
103 additional answers
    2015-06-11T16:05:14+00:00
    This happens to me in outlook--Hotmail.  Sometimes the words get split correctly--that is, the word left at the end of a line constitutes a word in itself, but most of the time nonsense syllable, or individual letters are left.  And sometimes Hotmail works correctly, and it moves the hanging letters to the next line.  Thanks.
  2. Stefan Blom 352K Reputation points MVP Volunteer Moderator
    2015-06-11T17:51:21+00:00
    Note that this forum only deals with Word. Re-post your question in the Outlook.com forum.
