How do you stop words from being split across two lines in Word 2010?
2010-08-10T23:06:00+00:00
Help please, have installed Word 2010 and cannot work out why the words get split at the end of a line, leaving half the word on one line and the other half getting pushed onto the next.  Any ideas much appreciated!
2014-11-26T10:34:35+00:00
The same problem with Microsoft Word can be solved by the following steps:
1- Close Word
2- Navigate to Start->Programs->Microsoft Office->Microsoft Office Tools->Microsoft Office Language Preference
3- Add Japanese
4- Open Word
5- In right Click menu: Select Paragraph...
6- Go to the "Asian Typography" Tab.
7- Deselect: "Allow Latin text to wrap in the middle of a word"
8- Click OK
The problem will be solved. Now if you don't want to have Japanese you can remove it from:
Good Luck!
2013-03-26T01:12:39+00:00
I have found the solution (a little late, yes, but useful nowadays since no one was able to figure it out). It has to do with the Japanese language support (I don't know why, but it is like that). I found the solution here: http://www.mraggarwal.com/2007/05/11/powerpoint-word-wrap-splitting-words-down-the-middle/ I hope it helps to the people having this issue and I also hope that Microsoft takes a look at this weird issue.
2010-08-11T08:23:35+00:00
Word should not split words like that. It suggests a serious bug with the printer driver. Try switching printers or updating your existing printer driver.
103 additional answers
    2015-05-17T00:01:57+00:00
    Yeah, well, it is neither, because you can easily check that. Funny how over six pages of complete nonsense with zero resolution. That means this problem IS happening, and that nobody has a clue how to fix it. I'm getting this even when I open a document with 365 ON-LINE. So, does MS's online version have corrupted fonts? I can also copy text to Notepad, open New document & paste it, AND it still does that stupid splitting up of words at the end of a line. OpenOffice is looking better every day.
  2. Stefan Blom 352.1K Reputation points MVP Volunteer Moderator
    2015-05-17T00:18:14+00:00
    Fonts are stored locally, so if you are looking at a web page or on something that you have downloaded to your hard drive won't make a difference. But, of course, you have to start looking at the other possible causes, beyond font corruption, if you have ruled that one out.
    I have already offered to look at the file. If you are concerned with the content, you can delete anything sensitive and then just create a shared version of the file on OneDrive or Dropbox.
