How do you stop words from being split across two lines in Word 2010?
2010-08-10T23:06:00+00:00
Help please, have installed Word 2010 and cannot work out why the words get split at the end of a line, leaving half the word on one line and the other half getting pushed onto the next.  Any ideas much appreciated!
2014-11-26T10:34:35+00:00
The same problem with Microsoft Word can be solved by the following steps:
1- Close Word
2- Navigate to Start->Programs->Microsoft Office->Microsoft Office Tools->Microsoft Office Language Preference
3- Add Japanese
4- Open Word
5- In right Click menu: Select Paragraph...
6- Go to the "Asian Typography" Tab.
7- Deselect: "Allow Latin text to wrap in the middle of a word"
8- Click OK
The problem will be solved. Now if you don't want to have Japanese you can remove it from:
Good Luck!
2013-03-26T01:12:39+00:00
I have found the solution (a little late, yes, but useful nowadays since no one was able to figure it out). It has to do with the Japanese language support (I don't know why, but it is like that). I found the solution here: http://www.mraggarwal.com/2007/05/11/powerpoint-word-wrap-splitting-words-down-the-middle/ I hope it helps to the people having this issue and I also hope that Microsoft takes a look at this weird issue.
2010-08-11T08:23:35+00:00
Word should not split words like that. It suggests a serious bug with the printer driver. Try switching printers or updating your existing printer driver.
103 additional answers
    2015-02-21T19:37:17+00:00
    Are there hyphens, too? If so, then all you have to do is turn off hyphenation. It's in the Page Layout ribbon tab.
    Herb Tyson Microsoft Word MVP Herb Tyson Word Bible Blog
    This is the simple answer and the one that worked for me. I have no idea how hyphenation got turned on, but this simple solution fixed it for me. Thanks so very much!
    2015-02-24T15:57:45+00:00
    This one worked for me in Word 2010. Thanks for help!
