How do you stop words from being split across two lines in Word 2010?
2010-08-10T23:06:00+00:00
Help please, have installed Word 2010 and cannot work out why the words get split at the end of a line, leaving half the word on one line and the other half getting pushed onto the next.  Any ideas much appreciated!
2014-11-26T10:34:35+00:00
The same problem with Microsoft Word can be solved by the following steps:
1- Close Word
2- Navigate to Start->Programs->Microsoft Office->Microsoft Office Tools->Microsoft Office Language Preference
3- Add Japanese
4- Open Word
5- In right Click menu: Select Paragraph...
6- Go to the "Asian Typography" Tab.
7- Deselect: "Allow Latin text to wrap in the middle of a word"
8- Click OK
The problem will be solved. Now if you don't want to have Japanese you can remove it from:
Good Luck!
2013-03-26T01:12:39+00:00
I have found the solution (a little late, yes, but useful nowadays since no one was able to figure it out). It has to do with the Japanese language support (I don't know why, but it is like that). I found the solution here: http://www.mraggarwal.com/2007/05/11/powerpoint-word-wrap-splitting-words-down-the-middle/ I hope it helps to the people having this issue and I also hope that Microsoft takes a look at this weird issue.
2010-08-11T08:23:35+00:00
Word should not split words like that. It suggests a serious bug with the printer driver. Try switching printers or updating your existing printer driver.
103 additional answers
    2014-07-07T12:55:13+00:00
    For word 2013 - this works for me.
    Instructions
      • 1
    Double-click the Microsoft Word program icon to launch the program. - 2
    Click the "Page Layout" tab to view the program's page layout options. - 3
    Click the "Hyphenation" option beneath the "Page Layout" heading, then select the "Automatic" option from the Hyphenation menu. Automatic hyphenation will now be enabled, disabling word wrapping in the process.
    Read more : http://www.ehow.com/how_8503962_turn-word-wrap-ms-word.html
  2. Suzanne S Barnhill 279.2K Reputation points MVP Volunteer Moderator
    2014-07-07T17:08:38+00:00
    This turns off hyphenation, but it does not solve the problem of words being split arbitrarily (without a hyphen) at the end of a line, which results from document or font corruption.
