How do you stop words from being split across two lines in Word 2010?
2010-08-10T23:06:00+00:00
Help please, have installed Word 2010 and cannot work out why the words get split at the end of a line, leaving half the word on one line and the other half getting pushed onto the next.  Any ideas much appreciated!
2014-11-26T10:34:35+00:00
The same problem with Microsoft Word can be solved by the following steps:
1- Close Word
2- Navigate to Start->Programs->Microsoft Office->Microsoft Office Tools->Microsoft Office Language Preference
3- Add Japanese
4- Open Word
5- In right Click menu: Select Paragraph...
6- Go to the "Asian Typography" Tab.
7- Deselect: "Allow Latin text to wrap in the middle of a word"
8- Click OK
The problem will be solved. Now if you don't want to have Japanese you can remove it from:
Good Luck!
2013-03-26T01:12:39+00:00
I have found the solution (a little late, yes, but useful nowadays since no one was able to figure it out). It has to do with the Japanese language support (I don't know why, but it is like that). I found the solution here: http://www.mraggarwal.com/2007/05/11/powerpoint-word-wrap-splitting-words-down-the-middle/ I hope it helps to the people having this issue and I also hope that Microsoft takes a look at this weird issue.
2010-08-11T08:23:35+00:00
Word should not split words like that. It suggests a serious bug with the printer driver. Try switching printers or updating your existing printer driver.
103 additional answers
    2013-12-12T14:17:49+00:00
    This worked perfectly! I had copied something written by a Chinese person (in English) and got the splitting across lines, but this fixed it immediately.  (edit: person I'm replying to said to copy the text into Notepad and then back to Word.)
    2014-03-17T20:48:59+00:00
    When I copy the section (including text boxes) and then paste with the "merge formatting" option it corrects that problem but strips out the font and font size formatting, as well as some boxes. So in a 200 page document this doesn't work - I'd have to take a hald day and go through and manually reformat everything to fix the problem of splitting words across lines.  This may have happened updating from Word 2007 to Word 2010, or making Dropbox.com edits may have caused it. If anyone has a better solution, let me know. Thanks.
