How do you stop words from being split across two lines in Word 2010?
2010-08-10T23:06:00+00:00
Help please, have installed Word 2010 and cannot work out why the words get split at the end of a line, leaving half the word on one line and the other half getting pushed onto the next.  Any ideas much appreciated!
2014-11-26T10:34:35+00:00
The same problem with Microsoft Word can be solved by the following steps:
1- Close Word
2- Navigate to Start->Programs->Microsoft Office->Microsoft Office Tools->Microsoft Office Language Preference
3- Add Japanese
4- Open Word
5- In right Click menu: Select Paragraph...
6- Go to the "Asian Typography" Tab.
7- Deselect: "Allow Latin text to wrap in the middle of a word"
8- Click OK
The problem will be solved. Now if you don't want to have Japanese you can remove it from:
Good Luck!
2013-03-26T01:12:39+00:00
I have found the solution (a little late, yes, but useful nowadays since no one was able to figure it out). It has to do with the Japanese language support (I don't know why, but it is like that). I found the solution here: http://www.mraggarwal.com/2007/05/11/powerpoint-word-wrap-splitting-words-down-the-middle/ I hope it helps to the people having this issue and I also hope that Microsoft takes a look at this weird issue.
2010-08-11T08:23:35+00:00
Word should not split words like that. It suggests a serious bug with the printer driver. Try switching printers or updating your existing printer driver.
103 additional answers
    2013-10-14T21:02:34+00:00
    That helps. Thank you!
  2. Suzanne S Barnhill 279.2K Reputation points MVP Volunteer Moderator
    2013-10-17T16:04:40+00:00
    Even in Word 2010, it is a global setting, yes; it can't be customized for a specific style. As for the unavailability of the setting in Word 2013, I received this answer from Microsoft:
    The change to the way that the Hyphenation dialog box works is actually by design, as noted in this KB article:http://support.microsoft.com/kb/2740483
    Background: As part of the work we did on the layout engine in 2013, we significantly improved the algorithm used to determine where to place hyphens.  The old algorithm was fairly unsophisticated and relied on a user input (the hyphenation zone setting) to determine hyphenation placement.  The new algorithms takes into account several properties of the text on the line and the paragraph and, as a result, rendered the hyphenation zone input obsolete.
    Even in Word 2013, a document in Compatibility Mode can use the hyphenation zone setting.
