How do you stop words from being split across two lines in Word 2010?
2010-08-10T23:06:00+00:00
Help please, have installed Word 2010 and cannot work out why the words get split at the end of a line, leaving half the word on one line and the other half getting pushed onto the next.  Any ideas much appreciated!
2014-11-26T10:34:35+00:00
The same problem with Microsoft Word can be solved by the following steps:
1- Close Word
2- Navigate to Start->Programs->Microsoft Office->Microsoft Office Tools->Microsoft Office Language Preference
3- Add Japanese
4- Open Word
5- In right Click menu: Select Paragraph...
6- Go to the "Asian Typography" Tab.
7- Deselect: "Allow Latin text to wrap in the middle of a word"
8- Click OK
The problem will be solved. Now if you don't want to have Japanese you can remove it from:
Good Luck!
2013-03-26T01:12:39+00:00
I have found the solution (a little late, yes, but useful nowadays since no one was able to figure it out). It has to do with the Japanese language support (I don't know why, but it is like that). I found the solution here: http://www.mraggarwal.com/2007/05/11/powerpoint-word-wrap-splitting-words-down-the-middle/ I hope it helps to the people having this issue and I also hope that Microsoft takes a look at this weird issue.
2010-08-11T08:23:35+00:00
Word should not split words like that. It suggests a serious bug with the printer driver. Try switching printers or updating your existing printer driver.
103 additional answers
  1. Charles Kenyon 170.8K Reputation points Volunteer Moderator
    2013-10-14T18:13:05+00:00
    Thank you for the advice, Mr. Kenyon and Ms. Barnhill.
    I'm positive that many more people are having this issue as we speak, and it is a pity that all this can't be avoided simply by a right click of the mouse followed by a "do not hyphenate" object menu command. Thank you!
    One thing you can do very easily is assign a keyboard shortcut(s) for your style(s).
    http://www.addbalance.com/usersguide/styles.htm#Keyboard
    2013-10-14T21:01:44+00:00
    I meant to say that the zone cannot be specified for every style (can it?), but yes, it can be modified for the entire document. I'm using Word 2010 student version. Thank you!
