How do you stop words from being split across two lines in Word 2010?
2010-08-10T23:06:00+00:00
Help please, have installed Word 2010 and cannot work out why the words get split at the end of a line, leaving half the word on one line and the other half getting pushed onto the next.  Any ideas much appreciated!
2014-11-26T10:34:35+00:00
The same problem with Microsoft Word can be solved by the following steps:
1- Close Word
2- Navigate to Start->Programs->Microsoft Office->Microsoft Office Tools->Microsoft Office Language Preference
3- Add Japanese
4- Open Word
5- In right Click menu: Select Paragraph...
6- Go to the "Asian Typography" Tab.
7- Deselect: "Allow Latin text to wrap in the middle of a word"
8- Click OK
The problem will be solved. Now if you don't want to have Japanese you can remove it from:
Good Luck!
2013-03-26T01:12:39+00:00
I have found the solution (a little late, yes, but useful nowadays since no one was able to figure it out). It has to do with the Japanese language support (I don't know why, but it is like that). I found the solution here: http://www.mraggarwal.com/2007/05/11/powerpoint-word-wrap-splitting-words-down-the-middle/ I hope it helps to the people having this issue and I also hope that Microsoft takes a look at this weird issue.
2010-08-11T08:23:35+00:00
Word should not split words like that. It suggests a serious bug with the printer driver. Try switching printers or updating your existing printer driver.
103 additional answers
  1. Suzanne S Barnhill 279.2K Reputation points MVP Volunteer Moderator
    2013-10-14T12:48:23+00:00
    When you format any amount of text as "no proofing" ("Do not check spelling or grammar"), this prevents Word from using any of the proofing tools--not just the spelling and grammar checkers but also the hyphenator. This check box is found in the Language dialog (Review | Language | Language | Set Proofing Language). For me, the easiest way to implement this (given the laborious amount of clicking required to get to this dialog--though it's only two clicks in Word 2003) is to create a No Proofing character style and apply it to selected text as needed. You can find more information on this at http://wordfaqs.mvps.org/MasterSpellCheck.htm#ExemptingText.
  2. Charles Kenyon 170.8K Reputation points Volunteer Moderator
    2013-10-14T16:46:59+00:00
    I routinely use such a character style in legal briefs for citation names. This has the advantage of letting me also specify that I want the names Italicized. When needed, I can also use Word's find Style feature to make sure that any citations are listed in a Table of Authorities in a brief.
    There have been briefs where I have had to change the citation style to Small Caps. Having it in a style was a real plus.
    This would, though, have to have superscripting or subscripting applied after application of the character style or use separate character styles (based on the citation style) for that purpose.
