How do you stop words from being split across two lines in Word 2010?
2010-08-10T23:06:00+00:00
Help please, have installed Word 2010 and cannot work out why the words get split at the end of a line, leaving half the word on one line and the other half getting pushed onto the next.  Any ideas much appreciated!
2014-11-26T10:34:35+00:00
The same problem with Microsoft Word can be solved by the following steps:
1- Close Word
2- Navigate to Start->Programs->Microsoft Office->Microsoft Office Tools->Microsoft Office Language Preference
3- Add Japanese
4- Open Word
5- In right Click menu: Select Paragraph...
6- Go to the "Asian Typography" Tab.
7- Deselect: "Allow Latin text to wrap in the middle of a word"
8- Click OK
The problem will be solved. Now if you don't want to have Japanese you can remove it from:
Good Luck!
2013-03-26T01:12:39+00:00
I have found the solution (a little late, yes, but useful nowadays since no one was able to figure it out). It has to do with the Japanese language support (I don't know why, but it is like that). I found the solution here: http://www.mraggarwal.com/2007/05/11/powerpoint-word-wrap-splitting-words-down-the-middle/ I hope it helps to the people having this issue and I also hope that Microsoft takes a look at this weird issue.
2010-08-11T08:23:35+00:00
Word should not split words like that. It suggests a serious bug with the printer driver. Try switching printers or updating your existing printer driver.
103 additional answers
    2013-10-13T19:25:41+00:00
    Word 2010
    Microsoft Office experts, Please:
    What if there is no space or hyphen to be made 'hard' using CTRL+SHIFT?
    I don't want to turn off hyphenation. But Word is hyphenating an Acronym or terms containing subscripts (e.g. UN was turned into U- N in the next line!) and will not allow me (the "do not hyphenate" is disabled for that word!).
    I know that there is a "hyphenate words in CAPS" is unchecked but that doesn't work.
    I've tried inserting an equations (thanks so another tip) but it has a different font and also interferes with line spacing.
    Will I have to get rid of hyphenation altogether?
    Thank you,
    Flavio
    PS: No, my document is not corrupt and this is not a problem with the printer!!!
    2013-10-13T19:36:55+00:00
    The specific term is:  uTNconc  (U and CONC are subscripts).
    The hyphen appears between T and N when the line breaks (uT-    Nconc).
    With auto-hyphenation I've tried using the "manual" hyphenation going over each word candidate to hyphenation but that specific term had the the "No" option disabled.
    I've just tried, for the 4th or 5th time also deleting the hyphen manually but it also deletes the "T".
    One more time and behold: the entire term was sent to the next line, possibly because the entire text was rearranged and that hyphen became unnecessary. But what if if happens again?
    Thank you.
