How do you stop words from being split across two lines in Word 2010?
2010-08-10T23:06:00+00:00
Help please, have installed Word 2010 and cannot work out why the words get split at the end of a line, leaving half the word on one line and the other half getting pushed onto the next.  Any ideas much appreciated!
2014-11-26T10:34:35+00:00
The same problem with Microsoft Word can be solved by the following steps:
1- Close Word
2- Navigate to Start->Programs->Microsoft Office->Microsoft Office Tools->Microsoft Office Language Preference
3- Add Japanese
4- Open Word
5- In right Click menu: Select Paragraph...
6- Go to the "Asian Typography" Tab.
7- Deselect: "Allow Latin text to wrap in the middle of a word"
8- Click OK
The problem will be solved. Now if you don't want to have Japanese you can remove it from:
Good Luck!
2013-03-26T01:12:39+00:00
I have found the solution (a little late, yes, but useful nowadays since no one was able to figure it out). It has to do with the Japanese language support (I don't know why, but it is like that). I found the solution here: http://www.mraggarwal.com/2007/05/11/powerpoint-word-wrap-splitting-words-down-the-middle/ I hope it helps to the people having this issue and I also hope that Microsoft takes a look at this weird issue.
2010-08-11T08:23:35+00:00
Word should not split words like that. It suggests a serious bug with the printer driver. Try switching printers or updating your existing printer driver.
103 additional answers
    2013-07-19T14:12:02+00:00
    Interesting twist on this topic. Bottleopener discovered hard spaces in text copied from the net. They do exist! Up to now, this discussion has been about putting them in, but Bottleopener wanted to take them out!
  2. Charles Kenyon 170.8K Reputation points Volunteer Moderator
    2013-07-19T14:13:24+00:00
    If text is filled with non-breaking spaces, yes, you will get this happening. That would be unusual.
    Something similar happens when all paragraphs are formatted to keep lines together and keep with next.
    Text imported from other sources is often problematic. I usually paste as plain text and reformat myself using Styles.
