Setting language for entire presentation all at once / Selecting all slides and all objects on all slides at once
2010-02-03T14:45:00+00:00
I want to change the language for spell checking after translating. I don't want to click each slide and then use Select All to select all objects on the slide and then set the language. There has to be a better way but I've never found it. Basically seems like a problem of not being able to select every object in a presentation at once (would have same problem setting one font for an entire presentation).
-Things I've tried:
  1. Setting the language without previously selecting anything. (Doesn't change the language of any text.)
  2. Using Select All in Outline view and then setting the language. (No change.)
  3. Using Select All in Slide view and then setting the language (Select All selects all objects on that slide.)
-I have to be missing something because this seems like basic functionality. I haven't been able to figure this out in earlier versions either.
2010-02-04T02:20:57+00:00
Try the following steps:-
Step 1:- By using Macro we can change the language in powerpoint for all slides.
Create a new macro:
  1. Go to Tools, Macro, and Visual Basic Editor.
  2. Insert a new empty module by selecting Insert, Module.
  3. Paste this code on the right panel and save the macro:
Option Explicit
Public Sub ChangeSpellCheckingLanguage()
    Dim j As Integer, k As Integer, scount As Integer, fcount As Integer
    scount = ActivePresentation.Slides.Count
    For j = 1 To scount
        fcount = ActivePresentation.Slides(j).Shapes.Count
        For k = 1 To fcount
            If ActivePresentation.Slides(j).Shapes(k).HasTextFrame Then
                ActivePresentation.Slides(j).Shapes(k) _
                .TextFrame.TextRange.LanguageID = msoLanguageIDEnglishAUS
            End If
        Next k
    Next j
End Sub
Step 2:- This "msoLanguageIDEnglishAUS" which is used in the above macro can be replaced by any desired language. The full list of languages can be found in this article http://msdn.microsoft.com/en-us/library/aa432635.aspx
Step 3:- Execute the macro (by pressing F5 within the editor, or by selecting Tools, Macro, Macros, ChangeSpellCheckingLanguage, and clicking Run).
After that all text elements within the presentation will have the new spelling language.
Ganesh Kumar N, Microsoft Answers Support Engineer.
• We appreciate your participation in MS Forums, Help us understand your needs better. To share your valuable Feedback please Click here.
2010-02-03T21:51:21+00:00
-Things I've tried:
Hi
I think the code here will do what you want:
http://support.microsoft.com/default.aspx?scid=kb;en-us;245468
Lucy
Lucy Thomson
PowerPoint MVP
an easier tomorrow
102 additional answers
    2012-08-10T15:24:08+00:00
    The only possible way without macros (and it will only work if all text is in placeholders) :
    Switch the left pane to outline
    Select all the text
    switch the language
    If you use macros the code in Lucy's link is much better than that posted by Ganesh.
    2012-08-10T11:48:14+00:00
    Did you find an answer without using macros ? I also face the same issue.
    2010-02-27T10:49:05+00:00
    And without a macro? I cannot give a macro code to more than 1,000 user in a company. I really need the possibility to change the proofing language easily. Can't there be the possibility to change the language in the same way as I change the font? Go to the master, select everything on the slide, change the language - that's it.
    Pia
    "Ganesh Kumar N" schrieb im Newsbeitrag news:719a1706-5439-4c24-9acb-89145df0700e...
    Create a new macro:
    Option Explicit
        For j = 1 To scount
            For k = 1 To fcount
                End If
            Next k
        Next j
    End Sub
    Pia Bork MVP Powerpoint Germany
