auto text, why won't it work or only works sporadically ...
2010-10-24T20:58:44+00:00
moved from word 2000 to word 2010 and now auto text which was copied over works only occasionally and randomly ... i have done the word 2010 tutorial ... googled ad nauseum about it and i can not figure it out ... in word 2000 i added the auto text and when typing a document if i started typing the words of the auto text a greyish box showed up with the entire text, i hit enter and kept typing ... it is hit or miss whether the box will show up ... i have tried adding new auto text and that does not work at all ... what am i doing wrong ???
  1. Stefan Blom 352.6K Reputation points MVP Volunteer Moderator
    2010-10-25T09:34:36+00:00
    how?
    It should work the way you described it: after you've typed sufficiently many characters for Word to uniquely identify a particular AutoText entry, you should see the prompt.
    To move individual items to the Normal template, use Insert tab | Quick Parts | Building Block Organizer.
    2010-10-25T09:21:35+00:00
    how?
  3. Stefan Blom 352.6K Reputation points MVP Volunteer Moderator
    2010-10-25T09:19:17+00:00
    In Word 2010, AutoComplete Suggestions only work with AutoText entries stored in the Normal template (or with entries stored in the template attached to the current document).
