A family of Microsoft word processing software products for creating web, email, and print documents.
I solved this problem by saving the troublesome file in what 2010 calls "compatability mode>"
I upgraded from Office 2007 to 2010 two weeks ago. Whenever I open up documents in Print Layout View that were created under earlier versions of Word (2000, 2003, 2007), Word replaces several of the fonts with something that looks like Arial bold.Sometimes it changes just the title fonts, sometime the entire body font--it's not always the same phenomenon in each document.
The Font window on the Home tab still shows the name of the original font being used in the document, but the screen does not show that font--it just shows whatever it replaces the font with. Repeat: even though the screen in showing a different font, the Font window on the Tab Screen shows the name of the font the document should be showing.
When I change to Draft View, the fonts all display properly, but I need the correct fonts in the Print Layout to show because the bogus font that Word substitutes throws off the accuracy of what I'm looking at.
Is anyone else having this problem?
Jeff
Eutactic, I finally tried this solution. I really was not comfortable deleting everything under \Office, but after backing up the registry, I gave it a try. So far it seems to have worked. I will be finishing an important project during the week, so I will have daily opportunities to see how this holds up.
Thanks for the recommendation.
Jeff
I believe I have solved this problem by simply backing up and deleting all the registry values in HKEY_CURRENT_USER\Software\Microsoft\Office. Obviously this is an extreme approach that wiped my preferences, but it appears to have done the trick.
Eutactic and Jay,
Sorry to announce that everything LOOKED okay for a few hours. Unfortunately, as I have been editing a document (that I've using as the test document), the problem has reappeared. Jay, I am sure that I am not the only person out there that uses Open Type fonts in Word documents. As you know, the point of Open Type fonts was cross-platform. Office 2007 NEVER had a problem like this.
Is there any possible way to get somebody at Microsoft to get on this right away? Just the posts below show that others are facing this problem. I suggest that this may become a fairly big problem.
My staff all just switched to Office 2010 and it will not act properly with Open fonts. This is really problematic for us: I have projects due at the end of the week that can't be finished with this font problem.
Could we please have some help?
Thank you.
Jeff
Thanks, Suzanne.
They certainly aren't working for me. I'm just trying check back regularly. It would be nice if they could get this fixed.
Jeff
