Word 2010 Font Problem: different fonts showing up on screen
2010-06-09T21:52:26+00:00
I upgraded from Office 2007 to 2010 two weeks ago. Whenever I open up documents in Print Layout View that were created under earlier versions of Word (2000, 2003, 2007), Word replaces several of the fonts with something that looks like Arial bold.Sometimes it changes just the title fonts, sometime the entire body font--it's not always the same phenomenon in each document.
The Font window on the Home tab still shows the name of the original font being used in the document, but the screen does not show that font--it just shows whatever it replaces the font with. Repeat: even though the screen in showing a different font, the Font window on the Tab Screen shows the name of the font the document should be showing.
When I change to Draft View, the fonts all display properly, but I need the correct fonts in the Print Layout to show because the bogus font that Word substitutes throws off the accuracy of what I'm looking at.
Is anyone else having this problem?
Jeff
2010-06-24T19:57:39+00:00
I solved this problem by saving the troublesome file in what 2010 calls "compatability mode>"
2010-06-28T15:17:36+00:00
Eutactic, I finally tried this solution. I really was not comfortable deleting everything under \Office, but after backing up the registry, I gave it a try. So far it seems to have worked. I will be finishing an important project during the week, so I will have daily opportunities to see how this holds up.
Thanks for the recommendation.
Jeff
2010-06-16T09:05:01+00:00
I believe I have solved this problem by simply backing up and deleting all the registry values in HKEY_CURRENT_USER\Software\Microsoft\Office. Obviously this is an extreme approach that wiped my preferences, but it appears to have done the trick.
161 additional answers
    2010-06-27T16:32:45+00:00
    You've lost me. What has this to do with Font Problems?
    Terry Farrell - MSWord MVP
    "Adamgggg" wrote in message news:*** Email address is removed for privacy *** .com...
    Can anyone explain exactly how to do this (backup (& restore??) Word registry settings)?
    Also, this problem is described at http://social.technet.microsoft.com/Forums/en/word/thread/0af832eb-46a1-4 165-a18b-5fd10e4fe36c?prof=required
    Terry Farrell
  2. Stefan Blom 351.6K Reputation points MVP Volunteer Moderator
    2010-06-27T16:36:59+00:00
    Earlier in the thread, someone suggested a registry edit. I'm guessing that caused "Adamgggg" to post his message. Here's a link to the entire thread in the web forum: http://social.answers.microsoft.com/Forums/en-US/wordcreate/thread/d2bf42b4-a287-4c4b-8052-07449f0f918d.
    Stefan Blom
    Microsoft Word MVP
    (Message posted via the Microsoft Answers NNTP Bridge)
    "TerFar" <=?utf-8?B?VGVyRmFy?=> wrote in message news:b3211fda-5a51-4d6c-b9c1-7b27007f4173...
    Terry Farrell
    Stefan Blom, Microsoft Word MVP
