A family of Microsoft word processing software products for creating web, email, and print documents.
I solved this problem by saving the troublesome file in what 2010 calls "compatability mode>"
I upgraded from Office 2007 to 2010 two weeks ago. Whenever I open up documents in Print Layout View that were created under earlier versions of Word (2000, 2003, 2007), Word replaces several of the fonts with something that looks like Arial bold.Sometimes it changes just the title fonts, sometime the entire body font--it's not always the same phenomenon in each document.
The Font window on the Home tab still shows the name of the original font being used in the document, but the screen does not show that font--it just shows whatever it replaces the font with. Repeat: even though the screen in showing a different font, the Font window on the Tab Screen shows the name of the font the document should be showing.
When I change to Draft View, the fonts all display properly, but I need the correct fonts in the Print Layout to show because the bogus font that Word substitutes throws off the accuracy of what I'm looking at.
Is anyone else having this problem?
Jeff
Eutactic, I finally tried this solution. I really was not comfortable deleting everything under \Office, but after backing up the registry, I gave it a try. So far it seems to have worked. I will be finishing an important project during the week, so I will have daily opportunities to see how this holds up.
Thanks for the recommendation.
Jeff
I believe I have solved this problem by simply backing up and deleting all the registry values in HKEY_CURRENT_USER\Software\Microsoft\Office. Obviously this is an extreme approach that wiped my preferences, but it appears to have done the trick.
I too have been having problems with this issue for some time.
In my case it was typically my everyday font of Adobe Minion Pro Open type with Postscript outlines.
The MS hotfix and problem suggessted above does not seem to match all the reports and screen shots on this thread.
In my case what has appeared to improve the scenario for me was under File Options Advanced in the section 'Display' to enable the option 'Disable hardware graphics acceleration'
My system is W7 x64, Office 2010 x32, ATI and NVIDIA 3d graphics cards.
However, it has not eradicated the issue: corrupted display fonts continue: switching to draft view and back almost always sorts them out
Those links are irrelevant to the problem described here.
Seriously, Microsoft... this is easily duplicated by countless people. Fix it... this is a serious regression.
