Word 2010 Font Problem: different fonts showing up on screen
2010-06-09T21:52:26+00:00
I upgraded from Office 2007 to 2010 two weeks ago. Whenever I open up documents in Print Layout View that were created under earlier versions of Word (2000, 2003, 2007), Word replaces several of the fonts with something that looks like Arial bold.Sometimes it changes just the title fonts, sometime the entire body font--it's not always the same phenomenon in each document.
The Font window on the Home tab still shows the name of the original font being used in the document, but the screen does not show that font--it just shows whatever it replaces the font with. Repeat: even though the screen in showing a different font, the Font window on the Tab Screen shows the name of the font the document should be showing.
When I change to Draft View, the fonts all display properly, but I need the correct fonts in the Print Layout to show because the bogus font that Word substitutes throws off the accuracy of what I'm looking at.
Is anyone else having this problem?
Jeff
2010-06-24T19:57:39+00:00
I solved this problem by saving the troublesome file in what 2010 calls "compatability mode>"
2010-06-28T15:17:36+00:00
Eutactic, I finally tried this solution. I really was not comfortable deleting everything under \Office, but after backing up the registry, I gave it a try. So far it seems to have worked. I will be finishing an important project during the week, so I will have daily opportunities to see how this holds up.
Thanks for the recommendation.
Jeff
2010-06-16T09:05:01+00:00
I believe I have solved this problem by simply backing up and deleting all the registry values in HKEY_CURRENT_USER\Software\Microsoft\Office. Obviously this is an extreme approach that wiped my preferences, but it appears to have done the trick.
161 additional answers
    2010-06-28T19:24:20+00:00
    Sorry to announce that everything LOOKED okay for a few hours. Unfortunately, as I have been editing a document (that I've using as the test document), the problem has reappeared. Jay, I am sure that I am not the only person out there that uses Open Type fonts in Word documents. As you know, the point of Open Type fonts was cross-platform. Office 2007 NEVER had a problem like this.
    Is there any possible way to get somebody at Microsoft to get on this right away? Just the posts below show that others are facing this problem. I suggest that this may become a fairly big problem.
    My staff all just switched to Office 2010 and it will not act properly with Open fonts. This is really problematic for us: I have projects due at the end of the week that can't be finished with this font problem.
    Could we please have some help?
    Shucks.  Glad I saw this before messing with my registry.
    I, too, am between a rock and a hard place.  I really like the improvements in 2010, but Word 2010 makes it very difficult to use the fonts I require.
    What is the procedure for filing a bug with MSFT?
    2010-06-28T20:37:11+00:00
    I've experienced the problem described in this thread on the following platform:
    Windows Server 2008 R2 x64 (used as a desktop OS) + Word 2010 64-bit
    In fact, you can see a screen-shot of the problem in my thread about Type 1 font support problems in Word 2010 . Here is that screen shot again:
    Specifically, for Adobe Type 1 fonts, Word will frequently fail to use the font for rendering.  It will use what looks to be Arial instead.  This did not seem to happen in the Office 2010 beta.  In my experience, this problem crept into the RTM version.  The problem also did not exist in Word 2003, the previous version I had used prior to the 2010 Beta.
    I definitely think there is a bug here and Microsoft should look into this post haste.
