How do I mass-extract email addresses out of several word documents at once?
2011-07-17T15:24:20+00:00
Hello All,
I have an important question.
I have a folder saved on my desktop with about 12000 word documents. All these documents have an email address in them but I want to know how to export all these email addresses without opening every single file one by one.
I hope somebody can help.
Kind regards,
EM
2011-07-18T05:02:41+00:00
It is not possible to extract the e-mail addresses without opening the documents, but the process can be automated with a macro. The following may do what you want, so try it on a folder containing ONLY a small subset of the documents before attempting to try it on a huge number of files. The following macro will extract any e-mail address in the documents and write them, one to a line, to a new document. It will not make any permanent changes to the documents themselves.
NOTE: IT WILL CRASH IF ANY OF THE DOCUMENTS ARE PASSWORD PROTECTED
http://www.gmayor.com/installing_macro.htm
Sub BatchProcess()
Dim strFilename As String
Dim strPath As String
Dim oDoc As Document
Dim oNewDoc As Document
Dim oRng As Range
Dim hLink As Hyperlink
Dim fDialog As FileDialog
Set oNewDoc = Documents.Add
Options.AutoFormatReplaceHyperlinks = True
Set fDialog = Application.FileDialog(msoFileDialogFolderPicker)
With fDialog
    .Title = "Select folder containing the documents and click OK"
    .AllowMultiSelect = False
    .InitialView = msoFileDialogViewList
    If .Show <> -1 Then
        MsgBox "Cancelled By User", , _
               "List Folder Contents"
        Exit Sub
    End If
    strPath = fDialog.SelectedItems.Item(1)
    If Right(strPath, 1) <> "" _
       Then strPath = strPath + ""
End With
If Left(strPath, 1) = Chr(34) Then
    strPath = Mid(strPath, 2, Len(strPath) - 2)
End If
strFilename = Dir$(strPath & "*.doc?")
While Len(strFilename) <> 0
    WordBasic.DisableAutoMacros 1
    Set oDoc = Documents.Open(strPath & strFilename)
    oDoc.Range.AutoFormat
    For Each hLink In oDoc.Hyperlinks
        If InStr(1, hLink.Address, "@") Then
            oNewDoc.Range.InsertAfter hLink.Range & vbCr
        End If
    Next hLink
    oDoc.Close SaveChanges:=wdDoNotSaveChanges
    WordBasic.DisableAutoMacros 0
    strFilename = Dir$()
Wend
oNewDoc.Paragraphs.Last.Range.Delete
oNewDoc.Range.Sort
oNewDoc.Range.Find.Execute FindText:="(*^13)@", _
                           MatchWildcards:=True, _
                           ReplaceWith:="\1", _
                           Replace:=wdReplaceAll
End Sub
45 additional answers
    2015-06-09T19:04:16+00:00
    Hi all,
    This code works in Word, but what needs to be changed so I can make it work in Excel?
    I want to extract emailadresses from excel files and put them in a new excel file or new word file.
    Anyone can let me know what has to be changed to this code?
    Chip
  2. Doug Robbins - MVP - Office Apps and Services 323.6K Reputation points MVP Volunteer Moderator
    2015-06-09T22:41:25+00:00
    It would be easier to help with that if you put a copy of the Excel Workbook in a folder on your OneDrive that you set to be shared and you copy and paste a link to that folder into a message that you post back here.
    2015-06-10T19:14:36+00:00
    Hey Doug,
    Well this is an example:
    https://onedrive.live.com/redir?resid=114309156909A90E!112&authkey=!AFqG2edtYUNIHNk&ithint=file%2cxls
    In some files there is more content and less emails or even none. And in some there are multiple sheets (mostly not). So I need a way to extract them all, a bit like what this word Macro thus but then for excel.
    The mails can be placed in a new word doc (like the current macro in this topic oes) or new excel file.
    I hope someone has a clue on how to do this or how to adapt the macro?
    Thanks!
    Chip
  4. Doug Robbins - MVP - Office Apps and Services 323.6K Reputation points MVP Volunteer Moderator
    2015-06-10T20:50:08+00:00
    When I try and access that folder, I receive the following message:
    You need to set the folder to be shared and then get a link to the folder and post it back here.
