How do I mass-extract email addresses out of several word documents at once?
2011-07-17T15:24:20+00:00
Hello All,
I have an important question.
I have a folder saved on my desktop with about 12000 word documents. All these documents have an email address in them but I want to know how to export all these email addresses without opening every single file one by one.
I hope somebody can help.
Kind regards,
EM
2011-07-18T05:02:41+00:00
It is not possible to extract the e-mail addresses without opening the documents, but the process can be automated with a macro. The following may do what you want, so try it on a folder containing ONLY a small subset of the documents before attempting to try it on a huge number of files. The following macro will extract any e-mail address in the documents and write them, one to a line, to a new document. It will not make any permanent changes to the documents themselves.
NOTE: IT WILL CRASH IF ANY OF THE DOCUMENTS ARE PASSWORD PROTECTED
http://www.gmayor.com/installing_macro.htm
Sub BatchProcess()
Dim strFilename As String
Dim strPath As String
Dim oDoc As Document
Dim oNewDoc As Document
Dim oRng As Range
Dim hLink As Hyperlink
Dim fDialog As FileDialog
Set oNewDoc = Documents.Add
Options.AutoFormatReplaceHyperlinks = True
Set fDialog = Application.FileDialog(msoFileDialogFolderPicker)
With fDialog
    .Title = "Select folder containing the documents and click OK"
    .AllowMultiSelect = False
    .InitialView = msoFileDialogViewList
    If .Show <> -1 Then
        MsgBox "Cancelled By User", , _
               "List Folder Contents"
        Exit Sub
    End If
    strPath = fDialog.SelectedItems.Item(1)
    If Right(strPath, 1) <> "" _
       Then strPath = strPath + ""
End With
If Left(strPath, 1) = Chr(34) Then
    strPath = Mid(strPath, 2, Len(strPath) - 2)
End If
strFilename = Dir$(strPath & "*.doc?")
While Len(strFilename) <> 0
    WordBasic.DisableAutoMacros 1
    Set oDoc = Documents.Open(strPath & strFilename)
    oDoc.Range.AutoFormat
    For Each hLink In oDoc.Hyperlinks
        If InStr(1, hLink.Address, "@") Then
            oNewDoc.Range.InsertAfter hLink.Range & vbCr
        End If
    Next hLink
    oDoc.Close SaveChanges:=wdDoNotSaveChanges
    WordBasic.DisableAutoMacros 0
    strFilename = Dir$()
Wend
oNewDoc.Paragraphs.Last.Range.Delete
oNewDoc.Range.Sort
oNewDoc.Range.Find.Execute FindText:="(*^13)@", _
                           MatchWildcards:=True, _
                           ReplaceWith:="\1", _
                           Replace:=wdReplaceAll
End Sub
45 additional answers
    2014-12-15T09:58:30+00:00
    As this is a very old thread, it needs an update. I would recommend using http://www.gmayor.com/document_batch_processes.htm to deal with the file handling and the error correction, using the following custom process to extract e-mail data from either the current document or a batch of documents.
    Function ExtractEMailAddress(oDoc As Document) As Boolean
    Dim bFound As Boolean
        On Error GoTo Err_Handler
        For Each oNewDoc In Documents
            If oNewDoc.name = "EmailList.docx" Then
                bFound = True
                Exit For
            End If
        Next oNewDoc
        If Not bFound Then
            oNewDoc.SaveAs2 "EmailList.docx"
        End If
                oNewDoc.Range.InsertAfter Replace(hLink.Address, "mailto:", "") & vbCr
            End If
        Next hLink
        ExtractEMailAddress = True
    lbl_Exit:
        Exit Function
    Err_Handler:
        ExtractEMailAddress = False
        Resume lbl_Exit
    End Function
    With regard to getting the name associated with the hyperlink, If the following doesn't work for you I would need to see an example. Names can be extraordinarily complex and may not fit the criteria of 'the first two words'. Furthermore whatever you may think of as a 'word' the application may not agree. However the following variation will include the first two words of the paragraph.
    Dim strText As String
                bFound = True
                Exit For
            End If
        Next oNewDoc
        If Not bFound Then
        End If
                strText = hLink.Range.Paragraphs(1).Range.Words(1) & _
    hLink.Range.Paragraphs(1).Range.Words(2) & "- " & _
                oNewDoc.Range.InsertAfter strText
            End If
        Next hLink
    lbl_Exit:
        Exit Function
    Err_Handler:
        Resume lbl_Exit
    End Function
  2. Doug Robbins - MVP - Office Apps and Services 323.6K Reputation points MVP Volunteer Moderator
    2014-12-15T10:06:25+00:00
    Try the following modification of Graham's code:
     Sub BatchProcess()
     Dim oRng As Range
     Dim rng As Range
     With fDialog
         If .Show <> -1 Then
             Exit Sub
         End If
     End With
     End If
                Set rng = hLink.Range.Paragraphs(1).Range
                rng.Collapse wdCollapseStart
                rng.MoveEnd wdWord, 2
                 oNewDoc.Range.InsertAfter rng.Text & " - " & hLink.Range & vbCr
             End If
         Next hLink
     Wend
     oNewDoc.Range.Sort
     End Sub
    2014-12-16T04:28:44+00:00
    Thank you so much all - especially Graham & Doug,
    You are right it is complex since it is not necessarily the first 2 words but it will aelast et the bulk of names ....
    John J Doe (PhD; Assoc Prof); Primate evolution ecology, conservation biology, tropical forest ecology, vertebrate-plant
    interactions; ******@gfbsd.com
    Betty Johnson (PhD 2001; Assoc Prof); Cu evolution, cultural transmission, behavioral ecology, evolutionary theory; E •; ******@gfbsd.com
    Teste Names (PhD U 1997; Assoc Prof); Environmental confli( cultural politics of neoliberalism, petropolitics, biopolitics; ******@gfbsd.com
    Google A Facebook (PhD 1980; Prof); Discours analysis, sociolinguistics, language and culture, language and gender/sexuali text; ******@gfbsd.com
    this is how the data appears mostly....but thanks anyway so much its a good start for me ..didnt realise the hlink could be extended to read the words in the paragraph as well...:)
  4. Doug Robbins - MVP - Office Apps and Services 323.6K Reputation points MVP Volunteer Moderator
    2014-12-16T05:17:47+00:00
    If you want to get the qualifications and the titles, such as (PhD: Assoc Prof),
    Use
                With rng
                    .MoveEndUntil Cset:=")", count:=wdForward
                    .MoveRight Unit:=wdCharacter, count:=1, Extend:=wdExtend
                End With
    in place of
    If you don't want the qualifications and the titles, use just
                With rng
                    .MoveEndUntil Cset:="(", count:=wdForward
                 End With
