How do I mass-extract email addresses out of several word documents at once?
2011-07-17T15:24:20+00:00
Hello All,
I have an important question.
I have a folder saved on my desktop with about 12000 word documents. All these documents have an email address in them but I want to know how to export all these email addresses without opening every single file one by one.
I hope somebody can help.
Kind regards,
EM
2011-07-18T05:02:41+00:00
It is not possible to extract the e-mail addresses without opening the documents, but the process can be automated with a macro. The following may do what you want, so try it on a folder containing ONLY a small subset of the documents before attempting to try it on a huge number of files. The following macro will extract any e-mail address in the documents and write them, one to a line, to a new document. It will not make any permanent changes to the documents themselves.
NOTE: IT WILL CRASH IF ANY OF THE DOCUMENTS ARE PASSWORD PROTECTED
http://www.gmayor.com/installing_macro.htm
Sub BatchProcess()
Dim strFilename As String
Dim strPath As String
Dim oDoc As Document
Dim oNewDoc As Document
Dim oRng As Range
Dim hLink As Hyperlink
Dim fDialog As FileDialog
Set oNewDoc = Documents.Add
Options.AutoFormatReplaceHyperlinks = True
Set fDialog = Application.FileDialog(msoFileDialogFolderPicker)
With fDialog
    .Title = "Select folder containing the documents and click OK"
    .AllowMultiSelect = False
    .InitialView = msoFileDialogViewList
    If .Show <> -1 Then
        MsgBox "Cancelled By User", , _
               "List Folder Contents"
        Exit Sub
    End If
    strPath = fDialog.SelectedItems.Item(1)
    If Right(strPath, 1) <> "" _
       Then strPath = strPath + ""
End With
If Left(strPath, 1) = Chr(34) Then
    strPath = Mid(strPath, 2, Len(strPath) - 2)
End If
strFilename = Dir$(strPath & "*.doc?")
While Len(strFilename) <> 0
    WordBasic.DisableAutoMacros 1
    Set oDoc = Documents.Open(strPath & strFilename)
    oDoc.Range.AutoFormat
    For Each hLink In oDoc.Hyperlinks
        If InStr(1, hLink.Address, "@") Then
            oNewDoc.Range.InsertAfter hLink.Range & vbCr
        End If
    Next hLink
    oDoc.Close SaveChanges:=wdDoNotSaveChanges
    WordBasic.DisableAutoMacros 0
    strFilename = Dir$()
Wend
oNewDoc.Paragraphs.Last.Range.Delete
oNewDoc.Range.Sort
oNewDoc.Range.Find.Execute FindText:="(*^13)@", _
                           MatchWildcards:=True, _
                           ReplaceWith:="\1", _
                           Replace:=wdReplaceAll
End Sub
45 additional answers
    2013-08-26T23:53:33+00:00
    I am sorry friend, you just lost me. Are you referring to like "Find and Replace" in word? also, the ^phttp and ^thttp are greek to me. Please elaborate if you dont mind.
    2013-08-27T00:02:08+00:00
    ok figured out the ^phttp and ^thttp thing. really slick. how to code that?
    Wow. you guys are amazing.
    2014-12-15T08:36:01+00:00
    Dear Graham Mayor,
    Your reply was perfect and has helped me with something else as well. But i am a little stumped how I can extract the first 2 words of the paragraph in which the email address appears...ie. each persons name appears int he beginning of the paragraph followed by some publications and then finally the email address.
    Your macros get the email addresses flawlessly but i need a name to go with each of these email address and these names are at the beginning of the same para in which the email is.
    Hope my question is clear and appreciate your time with this...thanks
  4. Paul Edstein 82,871 Reputation points Volunteer Moderator
    2014-12-15T09:54:18+00:00
    If the email addresses are the last string in each paragraph, you could do it without a macro, using a wildcard Find/Replace coded as:
    Find = ([!^13]@>[!^13]@>)*(<[0-9A-ÿ][!@ ]@@[! ]@>[! ^13]@>)
    Replace = \1 \2
