How do I mass-extract email addresses out of several word documents at once?
2011-07-17T15:24:20+00:00
Hello All,
I have an important question.
I have a folder saved on my desktop with about 12000 word documents. All these documents have an email address in them but I want to know how to export all these email addresses without opening every single file one by one.
I hope somebody can help.
Kind regards,
EM
2011-07-18T05:02:41+00:00
It is not possible to extract the e-mail addresses without opening the documents, but the process can be automated with a macro. The following may do what you want, so try it on a folder containing ONLY a small subset of the documents before attempting to try it on a huge number of files. The following macro will extract any e-mail address in the documents and write them, one to a line, to a new document. It will not make any permanent changes to the documents themselves.
NOTE: IT WILL CRASH IF ANY OF THE DOCUMENTS ARE PASSWORD PROTECTED
http://www.gmayor.com/installing_macro.htm
Sub BatchProcess()
Dim strFilename As String
Dim strPath As String
Dim oDoc As Document
Dim oNewDoc As Document
Dim oRng As Range
Dim hLink As Hyperlink
Dim fDialog As FileDialog
Set oNewDoc = Documents.Add
Options.AutoFormatReplaceHyperlinks = True
Set fDialog = Application.FileDialog(msoFileDialogFolderPicker)
With fDialog
    .Title = "Select folder containing the documents and click OK"
    .AllowMultiSelect = False
    .InitialView = msoFileDialogViewList
    If .Show <> -1 Then
        MsgBox "Cancelled By User", , _
               "List Folder Contents"
        Exit Sub
    End If
    strPath = fDialog.SelectedItems.Item(1)
    If Right(strPath, 1) <> "" _
       Then strPath = strPath + ""
End With
If Left(strPath, 1) = Chr(34) Then
    strPath = Mid(strPath, 2, Len(strPath) - 2)
End If
strFilename = Dir$(strPath & "*.doc?")
While Len(strFilename) <> 0
    WordBasic.DisableAutoMacros 1
    Set oDoc = Documents.Open(strPath & strFilename)
    oDoc.Range.AutoFormat
    For Each hLink In oDoc.Hyperlinks
        If InStr(1, hLink.Address, "@") Then
            oNewDoc.Range.InsertAfter hLink.Range & vbCr
        End If
    Next hLink
    oDoc.Close SaveChanges:=wdDoNotSaveChanges
    WordBasic.DisableAutoMacros 0
    strFilename = Dir$()
Wend
oNewDoc.Paragraphs.Last.Range.Delete
oNewDoc.Range.Sort
oNewDoc.Range.Find.Execute FindText:="(*^13)@", _
                           MatchWildcards:=True, _
                           ReplaceWith:="\1", _
                           Replace:=wdReplaceAll
End Sub
45 additional answers
    2013-08-26T10:19:55+00:00
    You da man! Perfecto. Works fantastic. Just sucked out the links and descriptions from 50 or so docs in less than a minute it seems.
    I dont want to push my luck with your generosity, but I just noticed that some of my docs have some google links that "I dont" want in the list. Is there a way to exclude importing anything with "google" in the link. I am learning so much here. I appreciate this more than you'll ever know. I have a thousands of docs I need to extract the links from, and this saves me so, so, so much time.
    Thanks again,
    Jeff
    2013-08-26T11:08:57+00:00
    I suspect if you add-in the bold bits it should work.
                If InStr(1, LCase(hLink.Address), "http") > 0 And _               InStr(1, LCase(hLink.Address), "google") = 0 Then
                    Set rngGet = hLink.Range
                    rngGet.MoveStart wdParagraph, -1
                    oNewDoc.Range.InsertAfter rngGet & vbCr
                End If
    Next hLink
    2013-08-26T19:32:16+00:00
    That's it! Works perfect.. Fast too. I really want to thank both of you guys (Doug and Graham.) Your help is sincerely appreciated. I cannot even begin to tell you how much time you guys saved me with this. You guys are both just too smart. Kudos! Now, I will try to figure out a way to suck the results into a simple Access database or something.
    Just FYI, I am doing this to save myself even more time when doing research for stuff I write. I have spend untold hours doing the research and getting the links, and I find myself using many of the same links again and again in some cases. Would be really sweet if I could just dump them all in a simple Access DB and search for them as needed. Maybe even create some sort of clickable "Paste to current position in Word" or something. But, one step at a time. This was the biggest hurdle for me I think.
    The search feature in Windows works okay, but it just returns too many full document links. I think extracting just the links and entering them into an access DB or maybe even a spreadsheet will work better for me.
    Anyway, thanks again guys., You're the best!
    Jeff
  4. Doug Robbins - MVP - Office Apps and Services 323.6K Reputation points MVP Volunteer Moderator
    2013-08-26T22:25:31+00:00
    The next thing that you should do (or it could be incorporated into the code is use the replace facility to replace
    ^phttp
    with
    ^thttp
    That will insert a tab space between the title and the url and you can then use the Convert Text to Table facility to convert everything into a table which can then be copied into Excel and then from Excel you can copy it and paste it into Access.
