How do I mass-extract email addresses out of several word documents at once?
2011-07-17T15:24:20+00:00
Hello All,
I have an important question.
I have a folder saved on my desktop with about 12000 word documents. All these documents have an email address in them but I want to know how to export all these email addresses without opening every single file one by one.
I hope somebody can help.
Kind regards,
EM
2011-07-18T05:02:41+00:00
It is not possible to extract the e-mail addresses without opening the documents, but the process can be automated with a macro. The following may do what you want, so try it on a folder containing ONLY a small subset of the documents before attempting to try it on a huge number of files. The following macro will extract any e-mail address in the documents and write them, one to a line, to a new document. It will not make any permanent changes to the documents themselves.
NOTE: IT WILL CRASH IF ANY OF THE DOCUMENTS ARE PASSWORD PROTECTED
http://www.gmayor.com/installing_macro.htm
Sub BatchProcess()
Dim strFilename As String
Dim strPath As String
Dim oDoc As Document
Dim oNewDoc As Document
Dim oRng As Range
Dim hLink As Hyperlink
Dim fDialog As FileDialog
Set oNewDoc = Documents.Add
Options.AutoFormatReplaceHyperlinks = True
Set fDialog = Application.FileDialog(msoFileDialogFolderPicker)
With fDialog
    .Title = "Select folder containing the documents and click OK"
    .AllowMultiSelect = False
    .InitialView = msoFileDialogViewList
    If .Show <> -1 Then
        MsgBox "Cancelled By User", , _
               "List Folder Contents"
        Exit Sub
    End If
    strPath = fDialog.SelectedItems.Item(1)
    If Right(strPath, 1) <> "" _
       Then strPath = strPath + ""
End With
If Left(strPath, 1) = Chr(34) Then
    strPath = Mid(strPath, 2, Len(strPath) - 2)
End If
strFilename = Dir$(strPath & "*.doc?")
While Len(strFilename) <> 0
    WordBasic.DisableAutoMacros 1
    Set oDoc = Documents.Open(strPath & strFilename)
    oDoc.Range.AutoFormat
    For Each hLink In oDoc.Hyperlinks
        If InStr(1, hLink.Address, "@") Then
            oNewDoc.Range.InsertAfter hLink.Range & vbCr
        End If
    Next hLink
    oDoc.Close SaveChanges:=wdDoNotSaveChanges
    WordBasic.DisableAutoMacros 0
    strFilename = Dir$()
Wend
oNewDoc.Paragraphs.Last.Range.Delete
oNewDoc.Range.Sort
oNewDoc.Range.Find.Execute FindText:="(*^13)@", _
                           MatchWildcards:=True, _
                           ReplaceWith:="\1", _
                           Replace:=wdReplaceAll
End Sub
45 additional answers
    2016-12-23T14:19:17+00:00
    Thanks.
    You provided correction to original macros but I should say that original macros works fine with .doc.
    It won't do filenames, which is exactly the reason I asked for help on this forum.
    Your function is more advanced, it extracts filenames as well as e-mail addresses I suppose but it's working only with .docx type.
    And it happens so that I need to process multiple .doc files.
    Any help and assistance to solve this complication would be invaluable.
  2. Doug Robbins - MVP - Office Apps and Services 323.6K Reputation points MVP Volunteer Moderator
    2016-12-24T02:26:13+00:00
    Use:
    Sub BatchProcess()
    Dim oRng As Range
    With fDialog
        If .Show <> -1 Then
            Exit Sub
        End If
    End With
    End If
                oNewDoc.Range.InsertAfter oDoc.Name & vbTab & hLink.Range & vbCr
            End If
        Next hLink
    Wend
    oNewDoc.Range.Sort
    oNewDoc.Range.ConvertToTable
    End Sub
    2016-12-27T14:00:25+00:00
    Doug, many thanks. That worked beautifully!
    It's incredible how helpful you are.
    My deepest respect.
    I'd like to share my slightly modified (amateurish but still may be of use to somebody) variant:
    Changes:
    1. Part of the path where folder selection dialog starts can be fixed, so you won't have to go through all directory structure again and again
    2. Removes .doc* extension from the filenames it saves
    3. Copies result (table) in clipboard and quits after completion
    I'd like to add one more feature - save the name of the chosen folder (with all *.doc files) in the first row (left cell) of the table but haven't figured it yet.)
    Sub BatchProcess()
    Application.ScreenUpdating = True
    Dim oRng As Range
    With fDialog
        .InitialFileName = "C:\Your path here" & ""
        If .Show <> -1 Then
            Exit Sub
        End If
    End With
    End If
            End If
        Next hLink
    Wend
    oNewDoc.Range.Sort
    oNewDoc.Range.Find.Execute FindText:=".doc*", _
                               ReplaceWith:="", _
    oNewDoc.Range.Tables(1).Select
    Selection.Copy
    ActiveWindow.Close
    Application.Quit
    End Sub
  4. Doug Robbins - MVP - Office Apps and Services 323.6K Reputation points MVP Volunteer Moderator
    2016-12-28T00:54:13+00:00
    Insert
    oNewDoc.Range.Tables(1).Cell(1, 1).Range.InsertBefore strPath
    between
    and
