How do I generate a numbered paragraph Word Cross Reference field in VB?
2010-10-06T22:23:01+00:00
Hi There,
Does anyone know how the 9 digit unique number used in a Microsoft Word 2003 SP3 cross reference field for a numbered paragraph is derived or calculated, and what VB function I can use to extract or create it?
I use a macro (see below) that creates and inserts a cross reference field. The aim is to quickly create a cross reference from a button rather than go through the tedious "insert>reference>cross reference and select" menus.
The macro tags the reference with a letter "b" followed by an 8 digit random number (eg toggle field codes shows "{ REF b70554752 \n \h }.
The behaviour of this method of cross referencing works well most of the time, but has a couple of annoying flaws.
Firstly, the small risk that a cross reference may be given the same number (ie the random number generator kicscks out the same number twice in a document!). Not really concerned about this as it is very unlikely to occur.
Secondly, and by far the biggest problem, is where a cross reference is created to a numbered paragraph, and the numbered paragraph is subsequently deleted. Instead of the cross reference going to "Error! - Reference Not Found" (as a 'manually inserted' cross reference does), it updates to a different, usually nearby, numbered paragraph.
On comparing the format of a 'manually inserted' cross reference field with my macro generated field, it appears that the "Microsoft" cross reference uses a 9 digit number that is somehow created uniquely based on the paragraph (for example "{ REF _Ref274201605 \n \h }"). This means that if the paragraph referred to is deleted, the reference is no longer valid and the bookmark (correctly) errors ever time.
Many thanks in advance!
Cheers
...Steve
For reference, the current macro is as follows:
___________________
Sub Add_crossRef_to_selected_para()
Dim n As Long
Dim myBookmark As String
n = Int(Rnd() * 100000000) + 1
With ActiveDocument.Bookmarks
.Add Range:=Selection.Range, Name:="b" & n
.DefaultSorting = wdSortByLocation
.ShowHidden = True
End With
Selection.InsertCrossReference ReferenceType:="Bookmark", ReferenceKind:= _
wdNumberNoContext, ReferenceItem:="b" & n, InsertAsHyperlink:=True, _
IncludePosition:=False
End Sub
________________________
    2010-10-10T23:32:13+00:00
    Hi macropod.
    Nearly there again! Initial testing has it working pretty much as expected. Some issues when there is a duplicate para, but that's quite rare and easy to fix in the pasted result (just delete the spurious xref).
    On large documents it takes a while  (15 seconds on the test doc) to give control back. Can anything be done about that?
    Cheers
    ...Steve
  2. Paul Edstein 82,871 Reputation points Volunteer Moderator
    2010-10-11T00:20:36+00:00
    Hi Steve,
    It surprises me that you'd get a spurious cross-reference with the last version, since it's testing for range equivalence rather than contents.
    It think the following should be significantly quicker on a large document:
    Sub CrossRefThisListPara()
    Dim i As Integer, xRefs As Variant, strNum As String
    xRefs = ActiveDocument.GetCrossReferenceItems(wdRefTypeNumberedItem)
    With Selection
      .Collapse wdCollapseEnd
      strNum = .Range.ListFormat.ListString
      On Error Resume Next
      For i = 1 To UBound(xRefs)
        If Split(Trim(xRefs(i)), " ")(0) = strNum Then
          If ActiveDocument.ListParagraphs(i).Range = .Paragraphs(1).Range Then
            .InsertCrossReference ReferenceType:=wdRefTypeNumberedItem, ReferenceKind:=wdNumberFullContext, _
            ReferenceItem:=i, InsertAsHyperlink:=True, IncludePosition:=False
            Exit Sub
          End If
        End If
      Next
    End With
    End Sub
    Cheers,
    macropod MS MVP - Word
    2010-10-11T01:21:10+00:00
    Hi macropod,
    Fixed the speed problem - well done!
    But (I think - I may be getting confused!!) it introduced a new one:-(
    In heading 4 and heading 5 it inserts a crossref to the first instance of the para that has the same text. eg inserting (in the test document) a cross ref at 4.1.3(b)(i) gives a value of 2.1(b)(i).
    Also tried it on one of my 'live' documents which uses multiple styles with heading numbering such asC1-61.3.11.1 for a level 3 heading, but lets get it working for the standard headings first:-)
    Cheers
    ...steve
  4. Paul Edstein 82,871 Reputation points Volunteer Moderator
    2010-10-11T03:42:42+00:00
    Hi Steve,
    Try this iteration:
    Application.ScreenUpdating = False
    Dim i As Integer, xRefs As Variant, rngTmp As Range
    With Selection
        If ActiveDocument.ListParagraphs(i).Range.BookmarkID = 0 Then
          Set rngTmp = ActiveDocument.ListParagraphs(i).Range
          With rngTmp
            .End = .Start
            .InsertCrossReference ReferenceType:=wdRefTypeNumberedItem, _
              ReferenceKind:=wdNumberFullContext, ReferenceItem:=i
            .MoveEnd wdCharacter, 1
            .Fields(1).Delete
          End With
        End If
      Next
        ReferenceItem:=.Paragraphs.First.Range.BookmarkID, InsertAsHyperlink:=True, IncludePosition:=False
    End With
    Application.ScreenUpdating = True
    End Sub
    What I've done is to add some code to ensure each list para has a bookmark ID allocated by Word, then simply insert the cross-reference to the current paragraph's bookmark ID. The code might run a little slowly the first time on a document with lots of list paragraphs that haven't been bookmarked, but thereafter should be quite quick.
    Cheers,
    2010-10-11T03:57:12+00:00
    Hi macropod,
    on my test document, it's horribly slow on initial and subsequent runs of the macro.
    Also inserts a bookmark to the begining of para 1 (HEading 1) in the few times I tried it, and incorrect in subsequent (eg inserts 2.2(b) in clause 2.2.3)
    Did you downlaod and try your macro in my test document?
    Cheers
    ...Steve
