How do I generate a numbered paragraph Word Cross Reference field in VB?
2010-10-06T22:23:01+00:00
Hi There,
Does anyone know how the 9 digit unique number used in a Microsoft Word 2003 SP3 cross reference field for a numbered paragraph is derived or calculated, and what VB function I can use to extract or create it?
I use a macro (see below) that creates and inserts a cross reference field. The aim is to quickly create a cross reference from a button rather than go through the tedious "insert>reference>cross reference and select" menus.
The macro tags the reference with a letter "b" followed by an 8 digit random number (eg toggle field codes shows "{ REF b70554752 \n \h }.
The behaviour of this method of cross referencing works well most of the time, but has a couple of annoying flaws.
Firstly, the small risk that a cross reference may be given the same number (ie the random number generator kicscks out the same number twice in a document!). Not really concerned about this as it is very unlikely to occur.
Secondly, and by far the biggest problem, is where a cross reference is created to a numbered paragraph, and the numbered paragraph is subsequently deleted. Instead of the cross reference going to "Error! - Reference Not Found" (as a 'manually inserted' cross reference does), it updates to a different, usually nearby, numbered paragraph.
On comparing the format of a 'manually inserted' cross reference field with my macro generated field, it appears that the "Microsoft" cross reference uses a 9 digit number that is somehow created uniquely based on the paragraph (for example "{ REF _Ref274201605 \n \h }"). This means that if the paragraph referred to is deleted, the reference is no longer valid and the bookmark (correctly) errors ever time.
Many thanks in advance!
Cheers
...Steve
For reference, the current macro is as follows:
___________________
Sub Add_crossRef_to_selected_para()
Dim n As Long
Dim myBookmark As String
n = Int(Rnd() * 100000000) + 1
With ActiveDocument.Bookmarks
.Add Range:=Selection.Range, Name:="b" & n
.DefaultSorting = wdSortByLocation
.ShowHidden = True
End With
Selection.InsertCrossReference ReferenceType:="Bookmark", ReferenceKind:= _
wdNumberNoContext, ReferenceItem:="b" & n, InsertAsHyperlink:=True, _
IncludePosition:=False
End Sub
________________________
  1. Paul Edstein 82,871 Reputation points Volunteer Moderator
    2010-10-07T00:27:35+00:00
    Hi Vidar,
    That's not how you go about inserting the cross-reference. The 9-digit # is essentially random and is allocated by Word. The following code shows how you'd insert a cross-reference at the selection point of the page # on which numbered paragraph 1.1 appears:
    Sub Demo()
    Dim i As Integer, xRefs As Variant
    xRefs = ActiveDocument.GetCrossReferenceItems(wdRefTypeNumberedItem)
    For i = 1 To UBound(xRefs)
      If Split(Trim(xRefs(i)), " ")(0) = "1.1" Then
        Selection.InsertCrossReference _
        ReferenceType:=wdRefTypeNumberedItem, _
        ReferenceKind:=wdPageNumber, ReferenceItem:=i, _
        InsertAsHyperlink:=True, IncludePosition:=False
        Exit For
      End If
    Next i
    End Sub
    macropod MS MVP - Word
    2010-10-07T21:16:49+00:00
    Thanks MacroPod.
    Sorry for the slow reply - I'd set the board to alert me when a reply came, but it didn't:-(
    That nearly works, thank you. I changed the ReferenceKind to be wdNumberNoContext as what I want is a cross reference  to the paragraph number.
    The problem now is that the hardcoded "1.1" needs to be dynamically replaced with whatever the paragraph number is where my curser is. Any advice on that? This was the challenge that led to the development of the orginal way of doing it. If I can resolve that issue then I think we have a winner:-))
    Thanks in advance!
    Cheers
    ...Steve
  3. Paul Edstein 82,871 Reputation points Volunteer Moderator
    2010-10-07T23:21:56+00:00
    Hi Steve,
    You want to cross-reference the current paragraph to itself? If so:
    Sub Demo()
    Dim i As Integer, xRefs, oPara As Variant
      For Each oPara In ActiveDocument.ListParagraphs
        If Selection.Paragraphs(1).Range = oPara.Range Then
          Selection.InsertCrossReference ReferenceType:=wdRefTypeNumberedItem, _
          ReferenceKind:=wdNumberNoContext, ReferenceItem:=i, InsertAsHyperlink:=True, IncludePosition:=False
          i = UBound(xRefs)
          Exit For
        End If
      Next
    Next
    End Sub
    2010-10-07T23:37:17+00:00
    Thanks Macropod,
    This doesn't work the way i want it either. Plus for documents with large numbers of numbered paras (eg where every para is numbered), it takes a really long time!!
    Can I email you a sample document off list?
    Cheers
    ...Steve
  5. Paul Edstein 82,871 Reputation points Volunteer Moderator
    2010-10-07T23:55:09+00:00
    Hi Steve,
    "This doesn't work the way i want it" isn't very descriptive. The code can be made much faster:
    Sub Demo()
    With Selection
        For Each oPara In .Range.ListParagraphs
          If .Paragraphs(1).Range = oPara.Range Then
            i = UBound(xRefs)
            Exit For
          End If
        Next
      Next
    End With
    End Sub
