Excel 2010 "There was a Problem sending the command to the program" Error
2011-01-28T07:40:23+00:00
Howdy.  After spending hours and hours online looking for a fix - trying the fixes offered time and time again, repairing with the disk, I am still not having any success fixing this error message.
Issue: Just installed Micro Office 2010 on my Windows 7 Ultimate 64-bit.  As a faculty member I had purchased the single license version of Professional from my school (shouldn't be an issue).  All other Micro Office programs seems to be functioning properly.  However, Excel will only open files from within the program - I cannot click the files and open them.  Even if I save a new file that I create - I still cannot open it from outside.
Yes, I have checked that the Ignore Programs option is unchecked.
Yes, I am not running any add-ins.
Please help.  Am at wits' end :(
**Post moved by the moderator to the right forum category.**
2011-01-28T19:14:28+00:00
Try the following steps:
Right click on Excel (.exe) > Properties > Compatibility > uncheck all the boxes
To access Excel (.exe), open the following location:
Windows 7 32bit: C:\Program Files\Microsoft Office\Office14
Windows 7 64bit: C:\Program Files(x86)\Microsoft Office\Office14
2011-07-24T21:23:12+00:00
I have just got rid of the problem.
i've got MS-Excel 64 bit.
I had turned ON the advanced option:
(File/Options -> Advanced ->  General ->)
Ignore other applications that use Dynamic Data Exchange (DDE)
I did that to get rid of the
cannot use object linking and embedding
error when starting Excel.
I consequently found that the problem with this error was that something had changed the DCOM User to my account instead of the launching User
(Component services\Computers\Mycomputer\DComConfig\Microsoft Excel Application-> Properties (right click) -> Identity (tab) change this user to the launching user)
When I did that cannot use object linking and embedding  was gone, but
was shown up each time I tried to double click an Excel file.
Finally I turned
back ON
and now everything seems to be fine!
Hope that helps
65 additional answers
    2012-12-19T21:40:55+00:00
    Ok, I had to share this. There were a lot of people that had success with "DDE" suggestion, but others, like me, were stating that the checkbox was already unchecked. Here is how I fixed mine:
    • Check the "DDE" checkbox
    • Try to open a file
    • Close all windows
    • Uncheck the "DDE" checkbox
    2012-12-20T19:59:09+00:00
    Legend. This has worked and saved me a lot of stress. Thank You!!!!!
    2013-01-31T01:16:40+00:00
    It Works...unchecking "Ignore other applications that use Dynamic Data Exchange (DDE)"
