Excel 2010 "There was a Problem sending the command to the program" Error
2011-01-28T07:40:23+00:00
Howdy.  After spending hours and hours online looking for a fix - trying the fixes offered time and time again, repairing with the disk, I am still not having any success fixing this error message.
Issue: Just installed Micro Office 2010 on my Windows 7 Ultimate 64-bit.  As a faculty member I had purchased the single license version of Professional from my school (shouldn't be an issue).  All other Micro Office programs seems to be functioning properly.  However, Excel will only open files from within the program - I cannot click the files and open them.  Even if I save a new file that I create - I still cannot open it from outside.
Yes, I have checked that the Ignore Programs option is unchecked.
Yes, I am not running any add-ins.
Please help.  Am at wits' end :(
**Post moved by the moderator to the right forum category.**
2011-01-28T19:14:28+00:00
Try the following steps:
Right click on Excel (.exe) > Properties > Compatibility > uncheck all the boxes
To access Excel (.exe), open the following location:
Windows 7 32bit: C:\Program Files\Microsoft Office\Office14
Windows 7 64bit: C:\Program Files(x86)\Microsoft Office\Office14
2011-07-24T21:23:12+00:00
I have just got rid of the problem.
i've got MS-Excel 64 bit.
I had turned ON the advanced option:
(File/Options -> Advanced ->  General ->)
Ignore other applications that use Dynamic Data Exchange (DDE)
I did that to get rid of the
cannot use object linking and embedding
error when starting Excel.
I consequently found that the problem with this error was that something had changed the DCOM User to my account instead of the launching User
(Component services\Computers\Mycomputer\DComConfig\Microsoft Excel Application-> Properties (right click) -> Identity (tab) change this user to the launching user)
When I did that cannot use object linking and embedding  was gone, but
was shown up each time I tried to double click an Excel file.
Finally I turned
back ON
and now everything seems to be fine!
Hope that helps
65 additional answers
    2012-03-20T20:39:19+00:00
    None of these solutions worked for me.  But I did find a solution.
    http://support.microsoft.com/kb/211494
    Read on this thread and there is a provided "fix it for me" .exe from Microsoft to fix the problem for you.  Just download and run the .exe and it should work.
    2012-04-02T20:37:12+00:00
    That which I thought solved my problem did not solve my problem.
    I believe the problem was with the Add-In:  Ribbon Hero 2.
    Initially, I just removed it from the Ribbon but it would always flash at the start of Excel and the Excel file wouldn’t open.  I removed Ribbon Hero 2 using Add/Remove and my troubles are over.
    2012-04-22T00:09:28+00:00
    Problem unresolved:
    I am using MS Office 2010 (service pack 1) 64 bit with Windows 7 Home premium 64 bit (service pack 1).
    When ever I double click any .xls file: "There was a problem...." error message is displayed. But if i first open excel and then open the file, in that case no problem.
    I have unchecked 'Ignore other applications that use DDE'. As a precaution, I checked the DDE option, closed excel, opened excel a 2nd time to uncheck the DDE option.
    I have disabled and removed all COM add-ins
    I have also unchecked all compatibility options.
    But still I get the error. I have also reinstalled office 2010 and applied all updates.
