Assuming a simple Excel file with a header row starting at A1 with column A being the words or phrases to find and column B the associated comments, then the following will work. It uses the function to read the named worksheet into an array, then uses the
array to provide the search and comment texts. By using this method, the process is very much faster than attempting to open and process the workbook line by line. It needs no reference to Excel.
Option Explicit
Sub FindAndCommentFromXLList()
'A Word macro by Graham Mayor
'Requires Function xlFillArray
Dim oDoc As Document
Dim oRng As Range
Dim i As Long
Dim Arr() As Variant
Dim sFindText As String
Dim sCommentText As String
Const strWorkbook As String = "C:\Path\Comments.xlsx"
Const strSheet As String = "Sheet1"
Set oDoc = ActiveDocument
Arr = xlFillArray(strWorkbook, strSheet)
For i = 0 To UBound(Arr, 2)
sFindText = Arr(0, i)
sCommentText = Arr(1, i)
If Len(sCommentText) > 255 Then
sCommentText = Left(sCommentText, 255)
End If
Set oRng = ActiveDocument.Range
With oRng.Find
.ClearFormatting
.Replacement.ClearFormatting
Do While .Execute(FindText:=sFindText, _
MatchWholeWord:=True, _
Forward:=True, _
Wrap:=wdFindStop) = True
oRng.Comments.Add oRng, sCommentText
oRng.Collapse wdCollapseEnd
DoEvents
Loop
End With
Next i
lbl_Exit:
Exit Sub
End Sub
Private Function xlFillArray(strWorkbook As String, _
strWorksheetName As String) As Variant
Dim RS As Object
Dim CN As Object
Dim iRows As Long
strWorksheetName = strWorksheetName & "$]"
Set CN = CreateObject("ADODB.Connection")
CN.Open ConnectionString:="Provider=Microsoft.ACE.OLEDB.12.0;" & _
"Data Source=" & strWorkbook & ";" & _
"Extended Properties=""Excel 12.0 Xml;HDR=YES"";"
Set RS = CreateObject("ADODB.Recordset")
RS.Open "SELECT * FROM [" & strWorksheetName, CN, 2, 1
With RS
.MoveLast
iRows = .RecordCount
.MoveFirst
End With
xlFillArray = RS.GetRows(iRows)
If RS.State = 1 Then RS.Close
Set RS = Nothing
If CN.State = 1 Then CN.Close
Set CN = Nothing
lbl_Exit:
Exit Function
End Function
