macro for performing more than one find and replace procedure at the same time
2010-08-07T18:21:24+00:00
ok, i've got to about 700!! find and replace procedures for a document of TWO MILLION words so this macro could save me about 4 hours of work.
i tried to rewrite this macro so that it would work but it didn't.  can anyone help me out
Sub Macro1()
Selection.Find.ClearFormatting
Selection.Find.Replacement.ClearFormatting
With Selection.Find
.Text = " mit der "
.Replacement.Text = " mitder"
.Text = " mit dem "
.Replacement.Text = " mitdem"
.Text = " mit den "
.Replacement.Text = " mitden"
.Forward = True
.Wrap = wdFindContinue
.Format = False
.MatchCase = False
.MatchWholeWord = False
.MatchWildcards = False
.MatchSoundsLike = False
.MatchAllWordForms = False
End With
Selection.Find.Execute Replace:=wdReplaceAll
End Sub
2010-08-07T18:56:51+00:00
ok, i got it work, i just copied it over
Sub Macro1()
' Macro1 Macro
' Macro recorded 8/7/10 by Seely Foley
    With Selection.Find
        .Text = " mit der "
        .Forward = True
        .Format = False
        .MatchCase = False
    End With
    With Selection.Find
        .Text = " mit den "
        .Forward = True
        .Format = False
        .MatchCase = False
    End With
End Sub
53 additional answers
    2015-02-26T09:12:29+00:00
    Final update: Once I made those same changes in the macros.dotm in the STARTUP folder, it worked with all documents with no errors.
  2. Doug Robbins - MVP - Office Apps and Services 323.6K Reputation points MVP Volunteer Moderator
    2015-02-26T10:06:26+00:00
    Sorry, that was a typo.
    2015-08-18T08:38:31+00:00
    unfortunately it does not work in all cases for me (Word 2013). In tests with small documents it runs well, in documents with > 500 words and more replacements Word freezes (no response) and i have to kill it manually.
    I am using a list of around 50 replacements (in a table).
    Can anyone tell me what is wrong with my code below?
    Sub ReplaceFromTableList()
        Selection.WholeStory
        Selection.LanguageID = wdDutch
        Application.CheckLanguage = False
    Dim oChanges As Document, oDoc As Document
    Dim oTable As Table
    Dim oRng As Range
    Dim rFindText As Range, rReplacement As Range
    Dim i As Long
    Dim sFname As String
    'Change the path in the line below to reflect the name and path of the table document
    sFname = "C:\Users\Tidde\Documents\Macros\FRtable.docx"
    Set oDoc = ActiveDocument
    Set oChanges = Documents.Open(FileName:=sFname, Visible:=False)
    Set oTable = oChanges.Tables(1)
    For i = 1 To oTable.Rows.Count
        Set oRng = oDoc.Range
        Set rFindText = oTable.Cell(i, 1).Range
        rFindText.End = rFindText.End - 1
        Set rReplacement = oTable.Cell(i, 2).Range
        rReplacement.End = rReplacement.End - 1
        With oRng.Find
                .ClearFormatting
                Do While .Execute(findText:=rFindText, _
                    MatchWholeWord:=True, _
                    MatchWildcards:=False, _
                    Forward:=True, _
                    Wrap:=wdFindContinue) = True
                    oRng.Text = rReplacement
                Loop
        End With
    Next i
    oChanges.Close wdDoNotSaveChanges
    End Sub
    2015-08-18T09:16:41+00:00
    I wrote up what I did (acknowledging the help from this forum, of course) in this blog post: https://cybertext.wordpress.com/2015/03/03/word-macro-to-run-multiple-wildcard-find-and-replace-routines/ You might want to compare your code with the code that works for me.
    It works well for me (except for some occasional weird things with replacing an 'x' within a word (i.e. NOT surrounded by spaces) with a multiplication sign.
    I have well over 120 F&R routines for non-breaking spaces in my table, and regularly run it over 50 to 400p Word documents. It takes only a couple of minutes. That said, I've only used it in Word 2010, not Word 2013. If I get a chance tomorrow, I'll test it in Word 2013 too and report back here.
    --Rhonda
