macro for performing more than one find and replace procedure at the same time
2010-08-07T18:21:24+00:00
ok, i've got to about 700!! find and replace procedures for a document of TWO MILLION words so this macro could save me about 4 hours of work.
i tried to rewrite this macro so that it would work but it didn't.  can anyone help me out
Sub Macro1()
Selection.Find.ClearFormatting
Selection.Find.Replacement.ClearFormatting
With Selection.Find
.Text = " mit der "
.Replacement.Text = " mitder"
.Text = " mit dem "
.Replacement.Text = " mitdem"
.Text = " mit den "
.Replacement.Text = " mitden"
.Forward = True
.Wrap = wdFindContinue
.Format = False
.MatchCase = False
.MatchWholeWord = False
.MatchWildcards = False
.MatchSoundsLike = False
.MatchAllWordForms = False
End With
Selection.Find.Execute Replace:=wdReplaceAll
End Sub
2010-08-07T18:56:51+00:00
ok, i got it work, i just copied it over
Sub Macro1()
' Macro1 Macro
' Macro recorded 8/7/10 by Seely Foley
    With Selection.Find
        .Text = " mit der "
        .Forward = True
        .Format = False
        .MatchCase = False
    End With
    With Selection.Find
        .Text = " mit den "
        .Forward = True
        .Format = False
        .MatchCase = False
    End With
End Sub
53 additional answers
    2015-02-25T08:59:42+00:00
    I realise this is a very old thread, but I needed a multiple find and replace (F&R) macro that dealt with 100+ wildcard F&R routines. This macro appears to work very well, but perhaps too well in my case. In case it matters, I'm using Word 2010.
    I created a doc with a single 2-column table with 'find' routines in the left column and 'replace' routines in the right. I used the wildcard syntax as I run all these as wildcard F&R routines. For example, I had a routine to search for a number followed by a space followed by a month name--in wildcard speak that's something like ([0-9])( )(May). I wanted to replace it with the same text except for the space, which I wanted as a non-breaking space; i.e. \1^s\3.
    I changed three lines in the macro -- the one that pointed to my Word doc containing the table, the 'MatchWholeWord' to False, and the 'MatchWildcards' to True. I changed nothing else.
    I added this slightly revised macro to a macros.dotm doc I store in my Word>STARTUP folder. And then I opened a large doc and ran the macro on it. After several minutes, it was finished. However, everything that was searched for was replaced by the ACTUAL text in the 'replace' column, and Word didn't consider it as wildcard syntax.
    The macro correctly searched for all instances in the first column, using the wildcard syntax. But the text it replaced it with ignored the wildcard setting and went in as \1^s\3. So instead of 9 May being replaced with 9<non-breaking space>May, it got replaced with \1^s\3.
    I also tried putting parentheses around the elements in the replace syntax--i.e. ( \1)(^s)(\3)--but again, it just went in as that text, and not as I would've expected had I done a Ctrl+H F&R routine with wildcards checked.
    Can anyone help? What line(s) do I need to add/change/delete in the macro for it to read the contents of the 'replace' column as wildcard syntax, and not as text?
    Thanks!
    --Rhonda
  2. Doug Robbins - MVP - Office Apps and Services 323.6K Reputation points MVP Volunteer Moderator
    2015-02-25T09:35:39+00:00
    It will be easier to help you if you show us the code of the macro that you are using.
    2015-02-25T22:14:42+00:00
    Hi Doug
    Here is the code:
    Sub ReplaceFromTableList()
    Dim oChanges As Document, oDoc As Document
    Dim oTable As Table
    Dim oRng As Range
    Dim rFindText As Range, rReplacement As Range
    Dim i As Long
    Dim sFname As String
    'Change the path in the line below to reflect the name and path of the table document
    sFname = "C:\Users\rhonda\AppData\Roaming\Microsoft\Word\STARTUP\find_and_replace_routines_macro.docx"
    Set oDoc = ActiveDocument
    Set oChanges = Documents.Open(FileName:=sFname, Visible:=False)
    Set oTable = oChanges.Tables(1)
    For i = 1 To oTable.Rows.Count
        Set oRng = oDoc.Range
        Set rFindText = oTable.Cell(i, 1).Range
        rFindText.End = rFindText.End - 1
        Set rReplacement = oTable.Cell(i, 2).Range
        rReplacement.End = rReplacement.End - 1
        With oRng.Find
                .ClearFormatting
                Do While .Execute(findText:=rFindText, _
                    MatchWildcards:=True, _
                    Forward:=True, _
                    Wrap:=wdFindContinue) = True
                    oRng.Text = rReplacement
                Loop
        End With
    Next i
    oChanges.Close wdDoNotSaveChanges
    End Sub
  4. Doug Robbins - MVP - Office Apps and Services 323.6K Reputation points MVP Volunteer Moderator
    2015-02-26T02:05:17+00:00
    Your code is just replacing the found text with the text contained in the replacement range.
    Using the following should make the replacement properly
     Dim oTable As Table
     Dim oRng As Range
     Dim i As Long
         With oRng.Find
                 .ClearFormatting
                     Forward:=True, _
                     Wrap:=wdFindContinue, Replacewith:=rReplacement) = True
                 Loop
         End With
     Next i
