macro for performing more than one find and replace procedure at the same time
2010-08-07T18:21:24+00:00
ok, i've got to about 700!! find and replace procedures for a document of TWO MILLION words so this macro could save me about 4 hours of work.
i tried to rewrite this macro so that it would work but it didn't.  can anyone help me out
Sub Macro1()
Selection.Find.ClearFormatting
Selection.Find.Replacement.ClearFormatting
With Selection.Find
.Text = " mit der "
.Replacement.Text = " mitder"
.Text = " mit dem "
.Replacement.Text = " mitdem"
.Text = " mit den "
.Replacement.Text = " mitden"
.Forward = True
.Wrap = wdFindContinue
.Format = False
.MatchCase = False
.MatchWholeWord = False
.MatchWildcards = False
.MatchSoundsLike = False
.MatchAllWordForms = False
End With
Selection.Find.Execute Replace:=wdReplaceAll
End Sub
2010-08-07T18:56:51+00:00
ok, i got it work, i just copied it over
Sub Macro1()
' Macro1 Macro
' Macro recorded 8/7/10 by Seely Foley
    With Selection.Find
        .Text = " mit der "
        .Forward = True
        .Format = False
        .MatchCase = False
    End With
    With Selection.Find
        .Text = " mit den "
        .Forward = True
        .Format = False
        .MatchCase = False
    End With
End Sub
53 additional answers
    2017-08-31T14:59:25+00:00
    You can simplify each of your find-replace blocks in the macro as follows:
      With Selection.Find
            .ClearFormatting
            .Text = " mit den "
            .Forward = True
            .Format = False
            .MatchCase = False
      End With
    If all your Find-Replace Operations have the following conditions, you can state them once at the top of the macro and then leave them out each find-replace block:
      With Selection.Find
            .Forward = True
            .Format = False
            .MatchCase = False
      End With
    then your find-replace blocks can simply be like so:
      With Selection.Find
            .ClearFormatting
            .Text = " mit den "
      End With
