macro for performing more than one find and replace procedure at the same time
2010-08-07T18:21:24+00:00
ok, i've got to about 700!! find and replace procedures for a document of TWO MILLION words so this macro could save me about 4 hours of work.
i tried to rewrite this macro so that it would work but it didn't.  can anyone help me out
Sub Macro1()
Selection.Find.ClearFormatting
Selection.Find.Replacement.ClearFormatting
With Selection.Find
.Text = " mit der "
.Replacement.Text = " mitder"
.Text = " mit dem "
.Replacement.Text = " mitdem"
.Text = " mit den "
.Replacement.Text = " mitden"
.Forward = True
.Wrap = wdFindContinue
.Format = False
.MatchCase = False
.MatchWholeWord = False
.MatchWildcards = False
.MatchSoundsLike = False
.MatchAllWordForms = False
End With
Selection.Find.Execute Replace:=wdReplaceAll
End Sub
2010-08-07T18:56:51+00:00
ok, i got it work, i just copied it over
Sub Macro1()
' Macro1 Macro
' Macro recorded 8/7/10 by Seely Foley
    With Selection.Find
        .Text = " mit der "
        .Forward = True
        .Format = False
        .MatchCase = False
    End With
    With Selection.Find
        .Text = " mit den "
        .Forward = True
        .Format = False
        .MatchCase = False
    End With
End Sub
53 additional answers
    2017-02-22T09:33:58+00:00
    This is really helpful to me - I've been trying to create a macro which introduced typos for literacy work.
    I have increased the number of columns on the table to 6, giving five typos for each correct spelling.  Unfortunately every time a word is replaced a new line is created -can you help?
    Sub ReplaceFromTableList()
    Dim oChanges As Document, oDoc As Document
    Dim oTable As Table
    Dim oRng As Range
    Dim rFindText As Range, rReplacement As Range
    Dim i As Long
    Dim sFname As String
    Dim x As Integer
    'Change the path in the line below to reflect the name and path of the table document
    sFname = "C:\Users\cthom\Desktop\changes.docx"
    Set oDoc = ActiveDocument
    Set oChanges = Documents.Open(FileName:=sFname, Visible:=False)
    Set oTable = oChanges.Tables(1)
    For i = 1 To oTable.Rows.Count
        Set oRng = oDoc.Range
        Set rFindText = oTable.Cell(i, 1).Range
        rFindText.End = rFindText.End - 1
        'Create a random x between 2 and 5
    Randomize
    x = Int(5 * Rnd()) + 1
         Set rReplacement = oTable.Cell(i, x).Range
        rReplacement.End = rReplacement.End - 1
        With oRng.Find
               ' .ClearFormatting
               ' .Replacement.ClearFormatting
                Do While .Execute(findText:=rFindText, _
                    MatchWholeWord:=True, _
                    MatchWildcards:=False, _
                    Forward:=True, _
                    Wrap:=wdFindContinue) = True
                    Randomize
                    oRng.Text = rReplacement
                Loop
        End With
    Next i
    oChanges.Close wdDoNotSaveChanges
    End Sub
  2. Doug Robbins - MVP - Office Apps and Services 323.6K Reputation points MVP Volunteer Moderator
    2017-02-22T10:20:46+00:00
    Replace
    with
    2017-02-22T19:32:10+00:00
    Thanks ever so much.  Solved my problem.
    Unfortunately there's always one more thing ..
    It goes strange when I try replacing I with i (something my students do all the time), and I cannot seem to replace capital letters with lower case.
    Thanks again for your help :-)
    Chris
  4. Doug Robbins - MVP - Office Apps and Services 323.6K Reputation points MVP Volunteer Moderator
    2017-02-22T23:20:05+00:00
    Try adding
    MatchCase:=True
    into the code (though it may interfere with some of the other find\replacements, depending upon how they are defined.
    Of course, if the I is just one letter within a Word, it will not be found because you have  MatchWholeWord:=True
