macro for performing more than one find and replace procedure at the same time
2010-08-07T18:21:24+00:00
ok, i've got to about 700!! find and replace procedures for a document of TWO MILLION words so this macro could save me about 4 hours of work.
i tried to rewrite this macro so that it would work but it didn't.  can anyone help me out
Sub Macro1()
Selection.Find.ClearFormatting
Selection.Find.Replacement.ClearFormatting
With Selection.Find
.Text = " mit der "
.Replacement.Text = " mitder"
.Text = " mit dem "
.Replacement.Text = " mitdem"
.Text = " mit den "
.Replacement.Text = " mitden"
.Forward = True
.Wrap = wdFindContinue
.Format = False
.MatchCase = False
.MatchWholeWord = False
.MatchWildcards = False
.MatchSoundsLike = False
.MatchAllWordForms = False
End With
Selection.Find.Execute Replace:=wdReplaceAll
End Sub
2010-08-07T18:56:51+00:00
ok, i got it work, i just copied it over
Sub Macro1()
' Macro1 Macro
' Macro recorded 8/7/10 by Seely Foley
    With Selection.Find
        .Text = " mit der "
        .Forward = True
        .Format = False
        .MatchCase = False
    End With
    With Selection.Find
        .Text = " mit den "
        .Forward = True
        .Format = False
        .MatchCase = False
    End With
End Sub
53 additional answers
    2016-09-13T19:25:33+00:00
    Hi again,
    I'd like to ask your help with adapting this marvelous macro in two additional ways. I've tried doing it myself with poor results.
    Here are the two adaptations:
    1. Macro to remove periods from acronyms. I developed this as an array macro in this thread:
    http://answers.microsoft.com/en-us/msoffice/forum/msoffice\_word-mso\_win10/macro-for-editing-acronyms/46d7b361-a8d5-4cf2-b0dd-f10c45ab3034
    As I kept working on it, though, I ended up with a find array with more than 200 search terms. So I'd like to adapt this macro such that the table consists of just one column, providing the "find what" items, which are in turn processed with the period-deleting routine. That routine, however, is a Do While block in my original macro, and that's the part I don't know how to adapt here. Also: using this macro with changes tracked is not an issue in this case.
    1. Macro to insert comments. Here's the thread I originally posted:
    http://answers.microsoft.com/en-us/msoffice/forum/msoffice\_word-mso\_win10/array-macro-for-adding-comments/b5303931-7852-4e85-b288-18cb0f017894
    Again, however, as I worked on this, the number of search terms and the length of comments ballooned beyond what I thought they'd be, and the processing became pretty slow. So for this one, I'm thinking there could be two columns, with the search terms on the left and the text of the corresponding comment on the right.
    Many thanks for your help...
  2. Paul Edstein 82,871 Reputation points Volunteer Moderator
    2016-09-13T21:32:10+00:00
    See my reply in your other thread (http://answers.microsoft.com/en-us/msoffice/forum/msoffice_word-mso_win10/macro-for-editing-acronyms/46d7b361-a8d5-4cf2-b0dd-f10c45ab3034). If required, the macro I've posted there could be modified to process only acronyms in a pre-defined list, without the Find itself having to loop through an array of such terms.
    2016-11-18T20:45:22+00:00
    Has anyone created a macro that would simply recreate Word's "auto-correct" function for text that already exists? Basically do a search and replace for every auto-correct entry?
    2016-12-06T17:09:17+00:00
    This is version is great -- it works perfectly!
