macro for performing more than one find and replace procedure at the same time
2010-08-07T18:21:24+00:00
ok, i've got to about 700!! find and replace procedures for a document of TWO MILLION words so this macro could save me about 4 hours of work.
i tried to rewrite this macro so that it would work but it didn't.  can anyone help me out
Sub Macro1()
Selection.Find.ClearFormatting
Selection.Find.Replacement.ClearFormatting
With Selection.Find
.Text = " mit der "
.Replacement.Text = " mitder"
.Text = " mit dem "
.Replacement.Text = " mitdem"
.Text = " mit den "
.Replacement.Text = " mitden"
.Forward = True
.Wrap = wdFindContinue
.Format = False
.MatchCase = False
.MatchWholeWord = False
.MatchWildcards = False
.MatchSoundsLike = False
.MatchAllWordForms = False
End With
Selection.Find.Execute Replace:=wdReplaceAll
End Sub
2010-08-07T18:56:51+00:00
ok, i got it work, i just copied it over
Sub Macro1()
' Macro1 Macro
' Macro recorded 8/7/10 by Seely Foley
    With Selection.Find
        .Text = " mit der "
        .Forward = True
        .Format = False
        .MatchCase = False
    End With
    With Selection.Find
        .Text = " mit den "
        .Forward = True
        .Format = False
        .MatchCase = False
    End With
End Sub
53 additional answers
    2016-08-18T21:47:13+00:00
    Graham's code replaces with a literal text string.  Try:
    Sub ReplaceFromTableList()
     Dim oDoc As Document, oDocFRPairs As Document
     Dim oTbl As Table
     Dim oRng As Range
     Dim strFind As String, strReplace As String
     Dim lngIndex As Long
      Set oDoc = ActiveDocument
      'Note change "ThisDocument.Path & "\Word List.docm" to reflect your actual FR pair list.
      Set oDocFRPairs = Documents.Open(FileName:=ThisDocument.Path & "\Word List.docm", Visible:=False)
      Set oTbl = oDocFRPairs.Tables(1)
      For lngIndex = 1 To oTbl.Rows.Count
       Set oRng = oTbl.Cell(lngIndex, 1).Range
       oRng.End = oRng.End - 1
       strFind = oRng.Text
       Set oRng = oTbl.Cell(lngIndex, 2).Range
       strReplace = oRng.Text
       Set oRng = oDoc.Range
       With oRng.Find
         .ClearFormatting
         .MatchWildcards = True
         .Text = strFind
         .Replacement.Text = strReplace
         .Replacement.Highlight = True
        End With
      Next lngIndex
    lbl_Exit:
      oDocFRPairs.Close wdDoNotSaveChanges
      Exit Sub
    End Sub
    2016-08-19T06:50:29+00:00
    Thanks so much! It works well, although it does lock up Word with a "Not Responding" message before it finishes. I guess that's understandable given how many searches I made it execute.
    2016-08-20T05:21:09+00:00
    Add a line
    DoEvents
    immediately before
    Next lngIndex
    which should eliminate the Not Responding message (though it should in any case complete).
    2016-08-21T01:28:02+00:00
    Thanks, that's helpful.
