Disable or Grey out Check box If Combo or Text Box Not Filled In
2010-10-14T18:47:39+00:00
I could get a combo box to disable text boxes using the code below, but how can I make this work if it isn't a text box and it is a check box?:
Private Sub Combo_Box_AfterUpdate()
Me.Text_Box.Enabled = (Me.Combo_Box.ListIndex >= 0)
End Sub
Microsoft 365 and Office | Access | For home | Windows
2010-10-14T21:56:54+00:00
A few things wrong here:
1.  You cannot compare something to Null.  Nothing equals Null, not even Null.  The IsNull function is used to determine if something is Null.
2.  In any case the Enabled property is either True or False, not Null.
So:
Private Sub Text_box_AfterUpdate()
    If IsNull(Me.text_box) Then
        Me.Text_box_2.Enabled = False
    Else
        Me.Text.box_2.Enabled = True
    End If
End Sub
or more succinctly:
     Me.Text.box_2.Enabled = Not IsNull(Me.text_box)
End Sub
If this is in a bound form and you want the Text.box_2 to be disabled when you move to an existing record where Text_box is Null, then also put the code in the form's Current event procedure.
Ken Sheridan, Stafford, England
56 additional answers
    2010-11-22T18:33:11+00:00
    All the fields below are just basic text and date fields fields that are enabled/disabled depending on if frame28 is checked or not.  As for the the second procedure it is just a yes/no check box that enables/disables a text field based on if the box is checked or not.  The code that I have below didn't work with the yes no field if I didn't specify no as the default value as I got the invalid use of null error.  Is there a way to have the field perform the same without specifying a default value?
    If not Frame28 Then ' if frame28 is ticked
        Me.Participant_Last_Name.Enabled = True
        Me.Participant_First_Name.Enabled = True
        Me.Birth_Date.Enabled = True
        Me.Unit_No.Enabled = True
        Me.Provider_Name.Enabled = True
        Me.Island.Enabled = True
        Me.Contact_Person.Enabled = True
        Me.Telephone_No.Enabled = True
        Me.Fax_No.Enabled = True
        Me.Relationship.Enabled = True
        Me.Supervisor_Name_Designated_Rep_Title.Enabled = True
      Else
        Me.Participant_Last_Name.Enabled = False
        Me.Participant_First_Name.Enabled = False
        Me.Birth_Date.Enabled = False
        Me.Unit_No.Enabled = False
        Me.Provider_Name.Enabled = False
        Me.Island.Enabled = False
        Me.Contact_Person.Enabled = False
        Me.Telephone_No.Enabled = False
        Me.Fax_No.Enabled = False
        Me.Relationship.Enabled = False
        Me.Supervisor_Name_Designated_Rep_Title.Enabled = False
      End If
    End Sub
    Private Sub Who_Was_Notified_Police_AfterUpdate()
    If Who_Was_Notified_Police Then
        Me.Who_Was_Notified_Police_Name.Enabled = True
      Else
        Me.Who_Was_Notified_Police_Name.Enabled = False
      End If
    End Sub
    THANKS
    2010-11-22T19:33:29+00:00
    Be sure to make a clear distinction between controls on the form and fields in the table.  For example, do not use the word field when you are talking about a control.  You keep saying that the Yes/No field must have a default value but Yes/No field's in the table do not need a default value because they can never be null.  With a problem like this one, the whole discussion can go out the window when the two words field and control are used interchangably.
    List each field that you are testing to decide if a control should be enabled or not.  Provide the field'sDataType (Number, Text, Yes/No, etc) in the table next to the field name.  Next to that provide the range of values the field might have.
    We do not care about the controls that you want to enable/disable.
    2010-11-22T20:19:18+00:00
    When I referred to field type I meant data type.  On the fields that are yes/no fields, is the fields that says default value, I wanted to leave it blank.  This is where I placed "no" to make the codes above work.  Before, it was blank.  When it was blank, the codes would give the invalid use of null error.
  4. Deleted
